Inleiding
The outside casing of the JBL Pulse 3 is the top portion of the device above the speaker grill. In order to take this part off the device, you will need to have removed the speaker grill first. For more information regarding troubleshooting, please visit our Troubleshooting Page.
Wat je nodig hebt
Lay the JBL Pulse 3 on its side as shown in the picture.
Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
Ca I Specifically buy the top ring
Opening is not as simple as demonstrated in Step 6. I have followed everything through, am I missing something?
Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
This phase could be difficult. Try to “twist” the speaker to have a little gap between both parts and insert gently a screwdriver or opening toile to spread the gap.
4 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Wherr can I get or buy top ring for Pulse 3?
Please see our device page with the link to the manufacturer’s website. You should be able to find it there.
I have one of these speakers, and as the delicate outer shell broke it seems nearly impossible to find a replacement…
Any chance to get spare parts in Europe? Thank you.
