Ga door naar hoofdinhoud
JBL Pulse 3 Motherboard Replacement
Wat je nodig hebt
  1. JBL Pulse 3 Motherboard Replacement, Speaker Grill: stap 1, afbeelding 1 van 1
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
  2. JBL Pulse 3 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Repeat step 1 for bottom right corner of speaker grill.
  3. JBL Pulse 3 Motherboard Replacement: stap 3, afbeelding 1 van 2 JBL Pulse 3 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
  4. JBL Pulse 3 Motherboard Replacement, Outside Casing: stap 5, afbeelding 1 van 2 JBL Pulse 3 Motherboard Replacement, Outside Casing: stap 5, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
  5. JBL Pulse 3 Motherboard Replacement: stap 6, afbeelding 1 van 2 JBL Pulse 3 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
  6. JBL Pulse 3 Motherboard Replacement: stap 7, afbeelding 1 van 2 JBL Pulse 3 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
  7. JBL Pulse 3 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Pull off the top disc of the JBL Pulse 3.
  8. JBL Pulse 3 Motherboard Replacement: stap 9, afbeelding 1 van 2 JBL Pulse 3 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
  9. JBL Pulse 3 Motherboard Replacement: stap 10, afbeelding 1 van 2 JBL Pulse 3 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
  10. JBL Pulse 3 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
  11. JBL Pulse 3 Motherboard Replacement, LED Light Display: stap 12, afbeelding 1 van 3 JBL Pulse 3 Motherboard Replacement, LED Light Display: stap 12, afbeelding 2 van 3 JBL Pulse 3 Motherboard Replacement, LED Light Display: stap 12, afbeelding 3 van 3
    • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
    • Pull the LED light display off of the JBL Pulse 3 base.
  12. JBL Pulse 3 Motherboard Replacement: stap 13, afbeelding 1 van 2 JBL Pulse 3 Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Use tweezers to pull the five connections off of the LED light display.
  13. JBL Pulse 3 Motherboard Replacement, Motherboard: stap 14, afbeelding 1 van 2 JBL Pulse 3 Motherboard Replacement, Motherboard: stap 14, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
  14. JBL Pulse 3 Motherboard Replacement: stap 15, afbeelding 1 van 3 JBL Pulse 3 Motherboard Replacement: stap 15, afbeelding 2 van 3 JBL Pulse 3 Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Pull out the motherboard slightly from the LED light display as shown. Using tweezers, unplug the three connections attached to the motherboard.
  15. JBL Pulse 3 Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Pull the rest of the motherboard out from the LED light display.
    • Using wire cutters, snip the black wire connecting to the base of the JBL Pulse 3 at the base of the motherboard. The motherboard should now be removed from the JBL Pulse 3.
Conclusie
Note: To replace the motherboard, you will need to re-solder the black wire to the motherboard.
Één opmerking
tengo un pulse 3 que la placa entro en corto… me gustaria saber si alguien me puede ayudar con el diagrama esquematico o algun foto donde pueda conseguir
Wilson Flores - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 32
Altijd: 3,443
