Inleiding
To complete this guide, you will need to disassemble your device and use a soldering iron to replace the power jack.
  1. Turn the device upside down so that the three rubber pads are facing up.
    • Turn the device upside down so that the three rubber pads are facing up.
  2. Use a heat gun (set to low) to apply heat  to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. Remove the heated rubber pad with a plastic opening tool.
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver. Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. Open the device along its seam. Be careful when separating the device because there are wires connecting the two seperate halves. Be careful when separating the device because there are wires connecting the two seperate halves.
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. MacBook-reparatiesets voor batterijen
    Vanaf $69.99
    Buy Now
    Vanaf $69.99
    Buy Now
  7. Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  8. Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device. Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
  9. Remove the three 1 cm T-10 Torx screws. Remove the three 1 cm T-10 Torx screws.
    • Remove the three 1 cm T-10 Torx screws.
  10. Carefully press out the white base tube and push up on the circuit board.
    • Carefully press out the white base tube and push up on the circuit board.
    • Note that there is a small wire connecting the circuit board to the base.
  11. Pull the white wire out of the hot glue. Pull the white wire out of the hot glue.
    • Pull the white wire out of the hot glue.
  12. Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver. Remove the heat sink; it should detach from the bottom of the device. Remove the heat sink; it should detach from the bottom of the device.
    • Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver.
    • Remove the heat sink; it should detach from the bottom of the device.
  13. Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board. Turn the device so that the base tube is on top. Remove the base tube by pulling up.
    • Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board.
    • Turn the device so that the base tube is on top.
    • Remove the base tube by pulling up.
    • May need to cut the rubber adhesive between the base tube to the circuit board.
  14. Turn the device upside down. Solder the back lead of the power jack until the solder melts. Heat the lead until the solder melts.
    • Turn the device upside down.
    • Solder the back lead of the power jack until the solder melts.
    • Heat the lead until the solder melts.
    • Remove the solder with the desoldering pump.
    • For help with soldering view the iFixit soldering guide
  15. Repeat step 13 for the other two leads
    • Repeat step 13 for the other two leads
  16. Remove the power jack.
    • Remove the power jack.
Conclusie
Replace the power jack with the new jack and resolder the leads. Follow the steps in reverse order to reassemble your device
Jared Everingham
332 Reputatie
3 handleidingen geschreven
Cal Poly, Team 9-28, Maness Winter 2014 Lid van Cal Poly, Team 9-28, Maness Winter 2014
CPSU-MANESS-W14S9G28
4 Leden
7 handleidingen geschreven
Één commentaar
Do you know where to find a sound jack for my JBL On Stage? Thanks
David Díaz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 9
Altijd: 806
