Inleiding
This guide is a step by step process on how to reach and remove the motherboard from the JBL Flip 5 speaker.
Wat je nodig hebt
Insert the flat edge of the metal spudger underneath the corner of the outer case.
Use the spudger to pry open the plastic clips that secure the outer case.
Begin by unscrewing the four 9.6 mm-long screws with the Philips #00 screwdriver.
The next part needed to remove covers each side and the power and bluetooth buttons in a middle strip along the speaker.
Begin (as shown in the second picture) by unscrewing the two screws (17mm each) with the Philips #00 screwdriver.
Then flip the device around and unscrew the other two screws (17 mm each) on the other side just the same.
Remove the black tape attached to the inside of the speaker.
The adhesive used is strong and may need more force if there is no progress.
