Inleiding
If the device will not charge and you have either tried a different working outlet or a different charger or even replaced the battery in the JBL Flip 5 speaker, you may want to try replacing the charging port.
Wat je nodig hebt
Insert the flat edge of the metal spudger underneath the corner of the outer case.
Use the spudger to pry open the plastic clips that secure the outer case.
Use a Phillips screwdriver to remove the four 17mm-long screws securing the passive radiator bracket.
