Inleiding
If the buttons are not working, and you have tried other troubleshooting technique, you can use this guide to remove and replace just the buttons, rather than having to buy a whole new speaker.
Wat je nodig hebt
Insert the flat edge of the metal spudger underneath the corner of the outer case.
Use the spudger to pry open the plastic clips that secure the outer case.
Begin by unscrewing the four 9.6 mm-long screws with the Philips #00 screwdriver.
The next part needed to remove covers each side and the power and bluetooth buttons in a middle strip along the speaker.
Begin (as shown in the second picture) by unscrewing the two screws (17mm each) with the Philips #00 screwdriver.
Then flip the device around and unscrew the other two screws (17 mm each) on the other side just the same.
Één opmerking
I think the newer JBL Flip 5 speakers have updated internals. I received a Flip 5 as a gift years ago and recently had to replace the battery using the tutorials on this website, and it went off without a hitch. I decided to buy another Flip 5 to use the party feature; I accidentally dropped it, and the buttons on the side stopped working. This is when I found out that the internals of my two JBL Flip 5 speakers looked different. This is only my second time trying to repair something on my own, any suggestions would be greatly appreciated.
