Inleiding
In some cases the battery block / stuck extreme hard inside. You can push it out, with a appropriate tool.
guide "JBL Flip 4 Battery Replacement" for blocked (swollen) battery.
A precise study the of the guide JBL Flip 4 Battery Replacement is required before starting (there are lot of useful comments). _
Wat je nodig hebt
Unscrew the USB-Modul.
Tilting the USB-Modul a bit (example: around 30 degrees)
The battery should be more visible now (image without battery).
or alternative remove the whole USB-Modul.
black flat flex / ribbon cable (here in image white) directly behind the USB-Modul,
black flat flex / ribbon cable (here in image white) across the flat,
thin microfon-cable, which rip off easily. Pull adhesive tape careful down.
Put the tool carefully on right side of the USB-Modul in. It's not allowed to be blocked by something. Nor on the side or down side.
The image shows the tool, after the battery was pressed out.
Maybe you can use a alcohol liquid to improve gliding properties. It will evaporation residue-free (in opposite of oil). If there are some glue remains from before, that can be also removed more easier.
The old battery are mounted by sponge rubber. By the bloat / expansion of the battery it's to big to push / pull out the old battery.
To improve mount, you may can add some rubber band to the battery. That will results the same like sponge rubber. It may also prevent too much heat at the battery.
The new battery is perfect centered in position.
Sort the battery cables: None of the cables inside should be upon the other.
Put the cap back.
If you have bad luck: The cable to the button may be damaged, while working. Follow this guide to replace that cables.
7 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Joe Musters helpt ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
2Gids Commentaar
Excellent tutoriel, facile à suivre bien que c'était assez laborieux avec la batterie gonflée et bloquée. Petite astuce supplémentaire: après lubrification à l'alcool, faire le mouvement contraire càd pousser un tout petit peu la batterie vers l'arrière(ça aide à décoincer) puis le pousser vers l'avant avec l'outil en bois, ça sort un peu plus facilement.
