Ga door naar hoofdinhoud
JBL Flip 4 Shell Replacement
Wat je nodig hebt
  1. JBL Flip 4 Shell Replacement, Shell: stap 1, afbeelding 1 van 3 JBL Flip 4 Shell Replacement, Shell: stap 1, afbeelding 2 van 3 JBL Flip 4 Shell Replacement, Shell: stap 1, afbeelding 3 van 3
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Watch out not to damage the clips on the buttons' side, pry open with caution.
    • Pull the cover off with your thumbs.
  2. JBL Flip 4 Shell Replacement: stap 2, afbeelding 1 van 3 JBL Flip 4 Shell Replacement: stap 2, afbeelding 2 van 3 JBL Flip 4 Shell Replacement: stap 2, afbeelding 3 van 3
    • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
    • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
    • Pry away one end of the rubber spine with your thumbs and it should come off.
    • Prying off the spine may take some persuading.
    • The speakers are strong magnets. Keep it away from other sensitive electronics.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Philip Pang
1.249 Reputatie
4 handleidingen geschreven
Cal Poly, Team S4-G3, White Fall 2018 Lid van Cal Poly, Team S4-G3, White Fall 2018
CPSU-WHITE-F18S4G3
4 Leden
36 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 43
Afgelopen 30 dagen: 197
Altijd: 13,116
