Ga door naar hoofdinhoud
JBL Clip 3 Motherboard Replacement
Wat je nodig hebt
  1. JBL Clip 3 Motherboard Replacement, Speaker Grill: stap 1, afbeelding 1 van 2 JBL Clip 3 Motherboard Replacement, Speaker Grill: stap 1, afbeelding 2 van 2
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Motherboard Replacement, Speaker Housing: stap 2, afbeelding 1 van 2 JBL Clip 3 Motherboard Replacement, Speaker Housing: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Motherboard Replacement: stap 4, afbeelding 1 van 2 JBL Clip 3 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Motherboard Replacement, Carabiner Clip: stap 5, afbeelding 1 van 2 JBL Clip 3 Motherboard Replacement, Carabiner Clip: stap 5, afbeelding 2 van 2
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
  6. JBL Clip 3 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 2 JBL Clip 3 Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Use a pair of tweezers to release the two cable connections from the motherboard.
    • The wires connecting to the battery are not very long, so be careful when removing them.
  7. JBL Clip 3 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the four screws.
  8. JBL Clip 3 Motherboard Replacement: stap 8, afbeelding 1 van 2 JBL Clip 3 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Lift the motherboard away from the speaker housing.
    • Desolder the two contact points.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tyler Molden
450 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-5, Petersen Spring 2022 Lid van UMass Dartmouth, Team 1-5, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G5
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 627
