Ga door naar hoofdinhoud
JBL Clip 3 Battery Replacement
Wat je nodig hebt
  1. JBL Clip 3 Battery Replacement, Speaker Grill: stap 1, afbeelding 1 van 2 JBL Clip 3 Battery Replacement, Speaker Grill: stap 1, afbeelding 2 van 2
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Battery Replacement, Speaker Housing: stap 2, afbeelding 1 van 2 JBL Clip 3 Battery Replacement, Speaker Housing: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Battery Replacement: stap 3, afbeelding 1 van 1
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Battery Replacement: stap 4, afbeelding 1 van 2 JBL Clip 3 Battery Replacement: stap 4, afbeelding 2 van 2
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Battery Replacement, Carabiner Clip: stap 5, afbeelding 1 van 2 JBL Clip 3 Battery Replacement, Carabiner Clip: stap 5, afbeelding 2 van 2
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
  6. JBL Clip 3 Battery Replacement, Speaker Battery: stap 6, afbeelding 1 van 2 JBL Clip 3 Battery Replacement, Speaker Battery: stap 6, afbeelding 2 van 2
    • Use a pair of tweezers to lift the two cable connections from the motherboard.
    • The wires connecting to the battery are not very long, so be careful when removing them.
  7. JBL Clip 3 Battery Replacement: stap 7, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the four screws.
  8. JBL Clip 3 Battery Replacement: stap 8, afbeelding 1 van 1
    • Gently lift the motherboard away from the speaker housing.
    • Be wary not to unseat the soldered connections when lifting the motherboard.
  9. JBL Clip 3 Battery Replacement: stap 9, afbeelding 1 van 2 JBL Clip 3 Battery Replacement: stap 9, afbeelding 2 van 2
    • Use the opening tool to carefully pry your way around the battery, slowly lifting it off of the epoxy until it fully releases.
    • Be mindful not to puncture the battery. It is a Lithium cell, so there is a bit of risk involved when completing this step. Be careful and patient, and there will not be any complications.
    • During reassembly, remember to superglue the new battery back into place.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kyle Montague
238 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-5, Petersen Spring 2022 Lid van UMass Dartmouth, Team 1-5, Petersen Spring 2022
UMASSD-PETERSEN-S22S1G5
3 Leden
6 handleidingen geschreven
2 opmerkingen
Thanks, but unless I missed something I don't see the recommended battery to replace with (only that it's a 1000mAh). Under "what you need" there's no mention of battery.
B.Bender - Antwoord
Amazon and others sell them. Just Google "JBL Clip 3 battery for sale". Price varies widely.
CalTee -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 56
Afgelopen 30 dagen: 219
Altijd: 4,832
