Ga door naar hoofdinhoud
JBL Clip 2 Speaker Replacement
Wat je nodig hebt
  1. JBL Clip 2 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Speaker Replacement: stap 2, afbeelding 1 van 1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
  3. JBL Clip 2 Speaker Replacement: stap 3, afbeelding 1 van 1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Speaker Replacement: stap 4, afbeelding 1 van 1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Michael Hong
1.014 Reputatie
5 handleidingen geschreven
UW Tacoma, Team 2-2, Rose Winter 2017 Lid van UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
4 Leden
7 handleidingen geschreven
6 opmerkingen
If no parts are required what are you replacing the speaker with?
Tom - Antwoord
Tom is right you know!
edward felix - Antwoord
The grill was glued into the T8 recesses. It needs glue to resemble. But how not to ruin the T8 heads for future work?
Gus Cannon - Antwoord
please we need to know where we can buy replacement speakers thanks email: chris.vargasrobles@gmail.com
chris robles - Antwoord
Hi, where I can buy the speaker please? Thank you.
Govan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 56
Altijd: 6,274
