Ga door naar hoofdinhoud
JBL Clip 2 Carabineer Mount Replacement
Wat je nodig hebt
  1. JBL Clip 2 Carabineer Mount Replacement, Carabineer Mount: stap 1, afbeelding 1 van 1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Carabineer Mount Replacement: stap 2, afbeelding 1 van 1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
    • If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
  3. JBL Clip 2 Carabineer Mount Replacement: stap 3, afbeelding 1 van 1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Carabineer Mount Replacement: stap 4, afbeelding 1 van 1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
  5. JBL Clip 2 Carabineer Mount Replacement: stap 5, afbeelding 1 van 1
    • There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
  6. JBL Clip 2 Carabineer Mount Replacement: stap 6, afbeelding 1 van 1
    • Slightly move the motherboard to the side to reveal the sides of battery, carefully using the blue plastic opening tool, remove the battery from the speaker casing.
    • Be careful not to disconnect any soldered wires connected to the motherboard and speaker casing.
  7. JBL Clip 2 Carabineer Mount Replacement: stap 7, afbeelding 1 van 1
    • There are two 3 mm T8 screws holding the carabineer in place, remove these two screws.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Michael Hong
1.014 Reputatie
5 handleidingen geschreven
UW Tacoma, Team 2-2, Rose Winter 2017 Lid van UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
4 Leden
7 handleidingen geschreven
2 opmerkingen
i want to find that part ,dou you have web link to by
breakdancesok - Antwoord
where can i find this piece please
Daniel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 88
Altijd: 8,735
