Inleiding
Since the Micro USB / AUX Port connectors are super-glued into the white casing, it is nearly impossible to replace it without replacing the whole piece of casing. Follow this guide to isolate and replace the white casing containing the Micro USB / AUX Port.
Wat je nodig hebt
Make sure the device is powered off before you begin to disassemble the speaker.
Remove the trim from the speaker using a jimmy or metal spudger.
Place the battery into the new white casing.
Reassemble the device by following the steps in reverse order.
13 andere personen hebben deze handleiding voltooid.
21 opmerkingen
Hi. This is the problem my speaker is having, but all I need to know is where to buy the replacement back. That's certainly something you should have included in your guide.
The purpose of a guide is to show how to fix the device, not obtain parts. I suggest eBay.
Joe Durand. Thank you for taking time out of your busy day to share such an enlightening comment.
Yeah what was the point of this if people can't actually do it. BS
The point is to guide people on the replacement of parts, not obtaining parts. I suggest eBay.
