Ga door naar hoofdinhoud
JBL Charge Battery Replacement
Wat je nodig hebt
  1. JBL Charge Battery Replacement, Disassembling JBL Charge Casing: stap 1, afbeelding 1 van 3 JBL Charge Battery Replacement, Disassembling JBL Charge Casing: stap 1, afbeelding 2 van 3 JBL Charge Battery Replacement, Disassembling JBL Charge Casing: stap 1, afbeelding 3 van 3
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Battery Replacement: stap 2, afbeelding 1 van 2 JBL Charge Battery Replacement: stap 2, afbeelding 2 van 2
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Battery Replacement: stap 3, afbeelding 1 van 2 JBL Charge Battery Replacement: stap 3, afbeelding 2 van 2
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
    This is NOT liquid Electrical tape! I recommend using 3M adhesive silicone. If you are doing this repair then you can find the 3m adhesive silicone at automotive stores. Liquid tape hardens and 3M adhesive remains mailable vs the rock hardening effect of liquid tape.
    Liz Ramirez - Antwoord
  4. JBL Charge Battery Replacement: stap 4, afbeelding 1 van 2 JBL Charge Battery Replacement: stap 4, afbeelding 2 van 2
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Battery Replacement: stap 5, afbeelding 1 van 2 JBL Charge Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
    The two screws on the right side (side with the USB port) are too long to extract with the iFixit screwdriver in the basic kit. I needed to use a regular thin PH2 screwdriver to get them out.
    Matthew Poole - Antwoord
    I had this problem also, whenever putting the screws back in there were still air pockets in the side with smaller screws
    Kamden Runyon - Antwoord
  6. JBL Charge Battery Replacement: stap 6, afbeelding 1 van 2 JBL Charge Battery Replacement: stap 6, afbeelding 2 van 2
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Battery Replacement: stap 7, afbeelding 1 van 2 JBL Charge Battery Replacement: stap 7, afbeelding 2 van 2
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
    Hi , Thanks a lot in my speacker i had broken plastic part which affect clear sound with your guide i open mine seasily and take it out now i have beand new sound which i had before. thanks again.
    kasravihasan - Antwoord
  8. JBL Charge Battery Replacement, Battery: stap 8, afbeelding 1 van 1
    • Turn your attention to the back casing removed in Step 7.
    where can i get the usb port with the cable that goes to mother board and it has the thre colors red black white please give me any place where i can buy it
    lozadajoseluis01 - Antwoord
  9. JBL Charge Battery Replacement: stap 9, afbeelding 1 van 1
    • Using a razor blade, remove the glue holding the battery cable in place.
    • Use multiple vertical cuts to remove pieces of the glue.
    • Be careful not to cut the battery cables.
    When reinstalling I used E600 glue to replace this goop of glue that is removed.
  10. JBL Charge Battery Replacement: stap 10, afbeelding 1 van 1
    • Remove the foam surrounding the battery cable.
    Dónde puedo conseguir los cablecitos de adentro
    Lauriano - Antwoord
  11. JBL Charge Battery Replacement: stap 11, afbeelding 1 van 1
    • To remove the battery, pull the battery cable through the hole.
    • This entire white piece needs to be replaced (if replacing the aux/usb port).
    Why does the whole White piece need to be replaced if replacing the USB port. I just took apart the case just to replace the USB port (not the battery). It looks like I can replace the port and not need a new case.
    Dave - Antwoord
    It looks like it would be difficult removing the USB assembly because mine looked very well glued in that little space meant for the module to fit.
    Thanks for this guide
    Jake Lalens - Antwoord
    I replaced the battery but it still won’t cheat fe, could the usb port be damaged and where can I purchase a usb port for my gen1 JBL Charge speaker?
    Bruce Smith - Antwoord
Conclusie
37 andere personen hebben deze handleiding voltooid.
Joe Durand
2.182 Reputatie
2 handleidingen geschreven
Cal Poly, Team 12-4, Lancaster Spring 2015 Lid van Cal Poly, Team 12-4, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G4
2 Leden
18 handleidingen geschreven
32 opmerkingen
How i replaced a new battery in myjbl reflect headphone bluetooth
Mohamad Lutfi - Antwoord
Please I need directions on replacing the battery of my jbl pulse speaker because it charges but doesn't indicate battery charging nor does it work.please I will be ver grateful.
Ifeanyi(kazhbone0147@gmail.com)
Ifeanyi Anaetoh - Antwoord
I need help.
My speaker no longer takes a charge.
Not even that old
Where do I get replacement battery. And what kind
Rose -
Your instructions state to replace the white cover, but do not say why it has to be replaced. Can you expound, please? Thank you,
Delton Eason Jr - Antwoord
Hi Delton, that is a good question. The entire cover has to be replaced if one is replacing the aux/USB ports.
You can ignore that note in this battery replacement guide. Good catch!
Joe Durand -
what type of battery should I be replacing the original battery with?
chrisdecay - Antwoord
Hi, I am Shashikant Shinde,
I have bought JBL Flip 3 ( Black ) few months back. Surprisingly the battery is not sustaining for long time. I feel the life of the battery should have been stronger than this. Within a year itself the battery has gone bad I think. Has any one a guide to replace the battery in JBL Flip 3 speaker. It is difficult to give the speaker in the service centre, as it is closed on saturday and sunday.
Shashikant Shinde - Antwoord
good step by step instructions! pictures totally helpful. any sugestions on where to get the replacement battery? thanks!
niccic - Antwoord
Its all very well to have installation instructions but where do you buy the battery and what are the reference numbers for the jlb spaekers
Barry Daniel - Antwoord
sir, i bought this system just six month back. now its not getting on atall . please tell me what should i do????
naiju davis - Antwoord
sir please give me a solution .
what kind of battery dies in 7 months of purchase. IT MEANS JBL CHARGE2 IS BAD PRODUCT.
eietu - Antwoord
sounds like you got a lemon ive had my jbl charge shadow since it came years ago havent had a single issue
Roger Shahan -
From where can i buy the battery for jbl charge 2
pjraysvarghese - Antwoord
Hi all,
Just realized i need to change battery in my JBL Charge. First would like to say thanks for the explanations on how to get to that bloody battery ^^
I have one question:
Is it possible to upgrade that battery with one that will last longer and maybe charge quicker?
If yes what battery can i use?
Thank you in advance.
HighJuice - Antwoord
Great instructions. Slightly diff on my charge 2+ but i got the whole idea from here. My charge 2+ started with batt issues about 1 month ago i could only do 1hr playback at mid vol…. i guess since oct 2015 with high usage (upto 2hrs per day) and most wknds for 5hrs and more. it was about time. New batt working great so far. Be careful not to drain your batt till red light flashes. Recharge when ur down to 2 lights and stop when the 5th light flashes. That way u protect from overcharge.
The charge 2+ is a great device.
nzalumulli - Antwoord
Does anyone know what type of battery the JBL pulse 1 actually needs? Also any further instructions on where to acquire this type of battery for a possible repair assuming that’s the actual issue with this slightly expensive/uselessspeaker (is it the battery or charge port that’s malfunctioning? Or both? If speaker turns on while plugged in connects to a device, sounds like the speaker is blown unless I turn it way down, then shuts off completely all while the battery meter indicates a full charge. I enjoy fixing m own tech, any info on the matter would be greatly appreciated!!!!
etsonkliza - Antwoord
Thanks! Great guide, much easier than it seemed at first. Now my speaker is working great again!
Great manuel,works like new after resetting the battery.thx
koenchristiaens22 - Antwoord
My JBL Charge (1) is about 3 years old, so battery life is badly deteriorated and is bloated a lot. Is it possible to keep using my JBL Charge always plugged to the charger even with the battery removed?
dukendelmo - Antwoord
Where do I get a new battery for JBL charge? I can tear it apart but what’s the point if I do t have a replacement battery
dirkjr10 - Antwoord
Please where can I get JBL Bluetooth Speaker battery in Nigeria. Thanks
LukmanAbubakar - Antwoord
Isn’t the usb port module available separatly?That weird because it isn’t glued into place on my speaker. It is just that the port itself has broken from the little board (module)
elzing3 - Antwoord
Great guide … thank you very much. If I was going to add anything, it would be a little warning about opening the main cover. I’ve got fairly strong hands, and I found it pretty difficult to fully separate the cover from the main body, even once I had it started at the corner shown in the guide. The adhesives used by the manufacturer around the edges of this cover are strong, and you have to be patient/careful as you apply the force required to pry all the edges of the cover up and away from the main body, e.g., so you don’t lose control of the Charge, the cover, or your tool as you’re working.
markwietstock - Antwoord
my jbl endurance peak only charges 10%
William Robinson - Antwoord
this IS not REAL!!!! omg no way
Angela Romo - Antwoord
excellent instructions. worked like a charm. JBL back to life.
k_stoute - Antwoord
My charge for a won't take a charge won't power up however after charging it for a few hours if I plug something into the USB it will charge the device I plug in there have you ever encountered that problem
Christian Pattillo - Antwoord
ottimo, immagini e indicazioni perfette
fabriziovittorio - Antwoord
Please share how to replace boombox1 battery please
Jayrome Ignoro - Antwoord
My JBL speaker will only work if I plug it in??? Please Help!!!
Kim Stevens - Antwoord
Can the usb port on the JBL 1st gen Charhe speaker be replaced and if so where can I purchase one, I replaced the battery but it still won’t charge with a bone hood cord?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 106
Afgelopen 30 dagen: 606
Altijd: 225,808
