Ga door naar hoofdinhoud
JBL Charge 5 Passive Bass Radiators Replacement
Wat je nodig hebt
  1. JBL Charge 5 Passive Bass Radiators Replacement, Fabric Case: stap 1, afbeelding 1 van 3 JBL Charge 5 Passive Bass Radiators Replacement, Fabric Case: stap 1, afbeelding 2 van 3 JBL Charge 5 Passive Bass Radiators Replacement, Fabric Case: stap 1, afbeelding 3 van 3
    • Ensure that the device is fully powered off and no cables are attached before proceeding with the repair.
    • This fabric cover is secured with plastic clips only. Depending on the model, the cover may be secured by both plastic clips and screws.
    • Insert the flat end of the Jimmy into the seam located between the fabric cover on the right side of the seam.
    • Pry upward on the fabric cover to release plastic clips on the right side of the seam.
  2. JBL Charge 5 Passive Bass Radiators Replacement: stap 2, afbeelding 1 van 3 JBL Charge 5 Passive Bass Radiators Replacement: stap 2, afbeelding 2 van 3 JBL Charge 5 Passive Bass Radiators Replacement: stap 2, afbeelding 3 van 3
    • Insert the flat end of the Jimmy into the seam between the fabric cover at the center of the seam and the left side of the seam.
    • Use the Jimmy to pry open the edge with the rubber texture, releasing the remaining plastic clips.
  3. JBL Charge 5 Passive Bass Radiators Replacement: stap 3, afbeelding 1 van 3 JBL Charge 5 Passive Bass Radiators Replacement: stap 3, afbeelding 2 van 3 JBL Charge 5 Passive Bass Radiators Replacement: stap 3, afbeelding 3 van 3
    • Use your hands to gently open the two halves of the casing and slide the fabric cover off of the interior housing.
  4. JBL Charge 5 Passive Bass Radiators Replacement, Passive Bass Radiators: stap 4, afbeelding 1 van 3 JBL Charge 5 Passive Bass Radiators Replacement, Passive Bass Radiators: stap 4, afbeelding 2 van 3 JBL Charge 5 Passive Bass Radiators Replacement, Passive Bass Radiators: stap 4, afbeelding 3 van 3
    • Using a spudger, pry the radiator off of the frame of the device.
    • Repeat on the other side if necessary.
Conclusie
Kat Whaley
753 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 68
Altijd: 276
