Inleiding
If the grille of your JBL Charge 4 has been damaged and you want to replace it or if you need to get into your device for further repair this guide will show you how. The only tools required are a plastic opening tool and a Phillips #0 screwdriver.
Wat je nodig hebt
Flip your speaker over and insert the plastic opening tool into the slit on the grille.
Pry away from yourself towards the back of the speaker to release the clip.
Repeat this process for the clip on the other side.
