Ga door naar hoofdinhoud
JBL Charge 3 Motherboard Replacement
Wat je nodig hebt
  1. JBL Charge 3 Motherboard Replacement, Front Cover: stap 1, afbeelding 1 van 3 JBL Charge 3 Motherboard Replacement, Front Cover: stap 1, afbeelding 2 van 3 JBL Charge 3 Motherboard Replacement, Front Cover: stap 1, afbeelding 3 van 3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
    Sometimes disassemblers forget that the first time they disassembled the item it didn’t want to give up easily: I didn’t like the forces I was having to apply at all, so I switched to two plastic prying tools per “corner” and one in-between them (total 5, you could use plectrums…) before I was happy the the forces were low enough not to break anything.
    Frank Puranik - Antwoord
    the front grill is supposed to be first not the back the back has longer while the front has shorter clip
    Water Bass Tester (Water BT) - Antwoord
    There are two Phillips head screws to remove before prying the cover off
    jason - Antwoord
    Where in south Africa can I buy jbl charge3 port bay replacement
    Donovan Fransman - Antwoord
    There appears to be different versions of the Charge 3. If you find it difficult to pry open a second side the two small screws mentioned by Jason will need to be removed but it also indicates that there will be some additional changes to this tear down that I will try to convey in the comments as well.
    john Ramirez - Antwoord
    Sadly I damaged the latches on my charge 3. There was more to it than just prying the front cover up. First, there is a small latch on both sides that you need to push down before pulling the front cover towards you that release the clips holding the front cover in place. Pull only slightly forward because… Second, in the front cover there are 6 circular notches connected to the front cover in tue four corners including the middle corners, you need to squeeze the front cover a little bit gently removing the notches so they dont break (like mine did).
    ralphkeneth_gomz - Antwoord
    Definitely had to watch about 10 videos and still couldn’t get it to pop out easily.. Took a look at the first picture in the next step and really took note of where the little hole that lets you through to push down the tab is. Once I took a look at that and combined the techniques I’d seen in some of the videos it finally popped off easily. https://www.youtube.com/watch?v=u7i0_nD9... I only watched the first minute of this video but it helped a good bit if anyone else is having trouble.
    Rowan Darko - Antwoord
    How do you know if the speakers or one of them is burned or broken.. i notice that one speaker is playing much less hard then the other one.. I wonder now if maybe there is another problem with my device.. Battery problem?
    Bukowski101 - Antwoord
  2. JBL Charge 3 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
    Include dissembling the plastic cover? cover?
    KanGoon - Antwoord
    @KanGoon Yes, on mine it took the removal of 6 (reasonably obvious) screws to remove that. I’ll try to insert a photo when I reassemble…
    Very good guide! Pics and descriptions make this easy!
    John G Petko - Antwoord
    There is a step missing here. How do you remove the rubber cover that covers the port?
    Phillip Luebke - Antwoord
    Gibt es eine Möglichkeit diese wieder wasserdicht zu bekommen?
    Furkan Karakelle - Antwoord
    Well, broke off the cover tabs. Have to remove 2 screws first. Might add that to the instructions.🤔
    Spartacus - Antwoord
  3. JBL Charge 3 Motherboard Replacement, Passive Radiators: stap 3, afbeelding 1 van 3 JBL Charge 3 Motherboard Replacement, Passive Radiators: stap 3, afbeelding 2 van 3 JBL Charge 3 Motherboard Replacement, Passive Radiators: stap 3, afbeelding 3 van 3
    • Remove the two 8mm Phillips #1 screws from the tabs.
    • NOTE: There may be only one screw.
    If your Charge 3 doesn’t look like the above. Do not do this step YET. Go directly to Step 7 removal of the battery. By doing the battery first it will tell you which radiator to remove and thus no need to remove both.
    NOTE:
    On a newer version of the Charge 3 this image will be very different. you will not find a screw. You will also notice that there are two tabs that if slightly lifted while rotating the radiator counter clockwise the radiator is easily removed. There is also no foam or breakable seal on the newer Charge 3.
  4. JBL Charge 3 Motherboard Replacement: stap 4, afbeelding 1 van 2 JBL Charge 3 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Insert the plastic opening tools underneath both tabs.
    Beim Modell 2016 geht es noch einfacher: Da ist es ein Bajonett-Verschluss (und nur 1 Schraube im vorigen Schritt). Man muss die Abdeckung nur ein paar Grad gegen den Uhrzeigersinn drehen und kann sie dann einfach abziehen. Schritt 5 und 6 entfallen.
    Franz - Antwoord
    I believe this is unnecessary, just turn the passive radiator counter clockwise and pull outward. I tried to use the pry tool and broke a plastic tab.
    Frank Krantz - Antwoord
    Tip— when you get to this part lightly tap the edge of the speaker on a hard surface— like you’re tapping a jar before opening it.
    maxthibodeaux - Antwoord
    Muchas gracias a todos, me dieron cada uno la guía perfecta.
    Rafael de la Torre Perez - Antwoord
    My charge 3 had less screws but the process was the same. Thanks for the instructions!
    Ryan Parker - Antwoord
  5. JBL Charge 3 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Twist and pull open the passive radiator. The left radiator twists off clockwise; the right counterclockwise.
    attention assez dur a enlever, le mien dur à tourner
    Walter Rousseau - Antwoord
  6. JBL Charge 3 Motherboard Replacement: stap 6, afbeelding 1 van 2 JBL Charge 3 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Repeat all previous steps for the other passive radiator.
    • NOTE: only the right radiator needs to be removed for changing the battery.
    right or left…. depends on how you view the Charge 3 i guess. No need to remove both radiators for a newer Charge 3. You can remove the battery cover first…find out what side the battery wires exit the battery compartment and then remove the radiator associated with that same side.
    Anybody else have major problems trying to twist the radiator back into position after replacing the battery? I’m having trouble getting the screw holes to line up again on the right radiator.
    Chapman Steamer 1 - Antwoord
    To twist back I used saliva so it will slide easier against the rubber
    Jaakob Wolff - Antwoord
  7. JBL Charge 3 Motherboard Replacement, Speaker: stap 7, afbeelding 1 van 2 JBL Charge 3 Motherboard Replacement, Speaker: stap 7, afbeelding 2 van 2
    • Remove the eight 10mm Phillips #1 screws from around the two front speakers.
    Die Frage : Ist ob man irgendwo Ersatz Lautsprecher bekommt ???
    nicowihnaleck - Antwoord
    Probier's mal hier, vergleiche aber ganz genau (Seriennummer GG…):
    https://ecommerce.mysav.eu/en/jbl/147-sp...
    VauWeh - Antwoord
  8. JBL Charge 3 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Pull gently on one of the speakers so it is outside of the housing. Be careful as it is still attached with the wires to the motherboard.
  9. JBL Charge 3 Motherboard Replacement: stap 9, afbeelding 1 van 3 JBL Charge 3 Motherboard Replacement: stap 9, afbeelding 2 van 3 JBL Charge 3 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart.
    Where can l buy those speaker for replacing
    Terrence Terrence - Antwoord
    Somebody know where I can buy These speakers ?
    motje - Antwoord
    The speakers that is on my charge 3 is soldered on doesn’t have the clips in picture
    travenature - Antwoord
  10. JBL Charge 3 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Repeat the previous step for the second connector.
  11. JBL Charge 3 Motherboard Replacement: stap 11, afbeelding 1 van 2 JBL Charge 3 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Grab the bundled cable connector that joins the speakers to the motherboard with tweezers. Gently pull the connector free.
  12. JBL Charge 3 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Now that the second speaker is disconnected from the motherboard, pull the speaker and wires out of the housing.
    where can i buy these speaker,i need to replace the left side speaker because it was already damaged
    geoffrey mustar - Antwoord
  13. JBL Charge 3 Motherboard Replacement, Battery: stap 13, afbeelding 1 van 3 JBL Charge 3 Motherboard Replacement, Battery: stap 13, afbeelding 2 van 3 JBL Charge 3 Motherboard Replacement, Battery: stap 13, afbeelding 3 van 3
    • Remove the six 8mm Phillips #1 screws from the outer battery cover.
    • Peel the outer battery cover away from the speaker housing.
    For the newer Charge 3 - there are two silver screws located on the opposite side of the charging ports ….. looking at the first picture above they would be in close proximity to the lower two red circles. However, they placed in horizontally not vertically. Once you remove these two screws you can lift the rubber off.
    Note: The rubber is hinged on the opposite side of the two removed screws by tabs. Be careful when rotating it off not to break the tabs.
    Once the rubber is removed…. you will be able to see the battery compartment. It has several black screws… one of which is wedged between the charging port rubber and the battery cover. You can gently pry up the rubber away to allow you to get a screw driver in to get the middle screw out.
    The battery compartment is water tight and has a seal. You will want to loosen all screws evenly so as not to tear or damage the rubber seal.
  14. JBL Charge 3 Motherboard Replacement: stap 14, afbeelding 1 van 3 JBL Charge 3 Motherboard Replacement: stap 14, afbeelding 2 van 3 JBL Charge 3 Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Remove the seven 8mm Phillips #1 screws from interior battery cover.
    • Remove the interior battery cover.
    The newer Charge 3 will have a solid black cover. Once removed the battery can be easily lifted out with your fingers. It is not taped in.
    Gently lift the battery to determine the radiator that needs to be removed. You can identify it by following the battery wiring. There is a small hole at the bottom of the battery compartment that the battery wires go through. The side with the battery wiring hole is the same side as the radiator that needs to be removed.
  15. JBL Charge 3 Motherboard Replacement: stap 15, afbeelding 1 van 2 JBL Charge 3 Motherboard Replacement: stap 15, afbeelding 2 van 2
    • Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard.
    mon problème d’origine était pas de charge sur secteur, dans mon cas nappe 11 connecteurs déconnectée. Je n’ai pas vu de système de retient pour cette nappe, je lui ai ajouté un petit point de colle, car bouge relativement beaucoup ! problème résolu
  16. JBL Charge 3 Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Pull the battery and battery cable out from their housing.
    Where can I find (shop) a battery replacement ?
    erik g5 - Antwoord
    yo tambien quiero una bateria donde la cosigo?
    henryovidioquispemamani -
    Does anyone know where I can buy a replacement battery?
    Tissaka Senarath - Antwoord
    Unbedingt die Isolierung um das Kabel und die Polster an den Ecken der Batterie von der alten an die neue basteln, sonst kann sie im Fach hin und her klappern.
    Se podria adactar este dispositivo directo a un cargador directo?
    Branlys Lopez Barnada - Antwoord
    I already did many things to my charge 3 and one of them was to put two direct cables to the battery to be able to charge it since the usb port was damaged and I could not find a replacement, next I will add 4 more batteries
    Ricky Almonte -
    perdon que te respondi en ingles, yo le puse un cable directo usb a la bateria ya que el puerto usb se daño y no pude encontrar repuestos
    Ricky Almonte -
  17. JBL Charge 3 Motherboard Replacement, Port Bay: stap 17, afbeelding 1 van 3 JBL Charge 3 Motherboard Replacement, Port Bay: stap 17, afbeelding 2 van 3 JBL Charge 3 Motherboard Replacement, Port Bay: stap 17, afbeelding 3 van 3
    • Take out the four 8mm Phillips #1 screws out of the port bay cover.
    • Wedge your plastic opening tool around the port bay to remove it.
    and then wiggle it directly (almost radially from the cylinder) out until you see the cables shown in the next step.
    Be careful not to damage the plastic gasket as you pull it out,
  18. JBL Charge 3 Motherboard Replacement: stap 18, afbeelding 1 van 3 JBL Charge 3 Motherboard Replacement: stap 18, afbeelding 2 van 3 JBL Charge 3 Motherboard Replacement: stap 18, afbeelding 3 van 3
    • Disconnect the two bundled cable connector from the port bay.
    there’s not much room to get you fingers in. Again I used prying tools to help me get the two connectors off the PCB
    How do i get another port bay
    pjimenez98 - Antwoord
  19. JBL Charge 3 Motherboard Replacement: stap 19, afbeelding 1 van 3 JBL Charge 3 Motherboard Replacement: stap 19, afbeelding 2 van 3 JBL Charge 3 Motherboard Replacement: stap 19, afbeelding 3 van 3
    • Remove the three 8mm Phillips #1 screws from the port bay circuit board.
    • Pull the port bay cover off of the circuit board.
    Be careful not to break the 2 plastic lugs you can see just below (on the photo) the 2 screws at the edges
  20. JBL Charge 3 Motherboard Replacement: stap 20, afbeelding 1 van 2 JBL Charge 3 Motherboard Replacement: stap 20, afbeelding 2 van 2
    • Desolder the USB, MicroUSB, or AUX port off of the circuit board.
    Salve, dove posso ordinare la presa usb piccola di ricarica, c’è un sito apposito?
    Robert James Hanrahan - Antwoord
  21. JBL Charge 3 Motherboard Replacement, Motherboard: stap 21, afbeelding 1 van 3 JBL Charge 3 Motherboard Replacement, Motherboard: stap 21, afbeelding 2 van 3 JBL Charge 3 Motherboard Replacement, Motherboard: stap 21, afbeelding 3 van 3
    • Remove the two 9mm Phillips #1 screws holding in the sides of the motherboard.
  22. JBL Charge 3 Motherboard Replacement: stap 22, afbeelding 1 van 2 JBL Charge 3 Motherboard Replacement: stap 22, afbeelding 2 van 2
    • Gently pull the bundled cable connector on the motherboard.
    I lost that cable what to do
    Dynamite Gaming - Antwoord
  23. JBL Charge 3 Motherboard Replacement: stap 23, afbeelding 1 van 2 JBL Charge 3 Motherboard Replacement: stap 23, afbeelding 2 van 2
    • Gently pull the golden connector off of the motherboard.
    Buenos días, se me despegó el otro extremo del cable del conector dorado y quisiera que me indiquen en qué lugar se vuelve a conectar. Muchas gracias
    Javier Cristanchi - Antwoord
  24. JBL Charge 3 Motherboard Replacement: stap 24, afbeelding 1 van 3 JBL Charge 3 Motherboard Replacement: stap 24, afbeelding 2 van 3 JBL Charge 3 Motherboard Replacement: stap 24, afbeelding 3 van 3
    • Flip open the top flap on the two ZIF connectors.
    • Gently pull out the ZIF connector cables with tweezers.
    Ya mine was glued together :(
    nuotio zz - Antwoord
  25. JBL Charge 3 Motherboard Replacement: stap 25, afbeelding 1 van 1
    • Slide the motherboard out of the housing.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Sunmin Yoon
1.826 Reputatie
2 handleidingen geschreven
Cal Poly, Team S13-G1, White Fall 2018 Lid van Cal Poly, Team S13-G1, White Fall 2018
CPSU-WHITE-F18S13G1
3 Leden
26 handleidingen geschreven
10 opmerkingen
Internation version is different. There are no screws for passive radiotors.
Tr0ll05aur0s 3z - Antwoord
You have to twist it. I have to managed to get it open because there is no video on youtube (I can’t find any)
Tr0ll05aur0s 3z -
If that even is Charge 3.
Tr0ll05aur0s 3z -
My JBL charge 3 is not charging …please give me idea to fix ..but it’s working perfectly only
nagendra.shriyan - Antwoord
My jbl charge are charging but it won't turn on…… i have tried several times to turn it on but it won't turn…… hoping for solutions……
cire_012881 - Antwoord
hello mate! did you find any solution?
baran.florin -
MAybe your battery or your power button is dead
Max Mustermann -
Where can I buy the motherboard?
leong065 - Antwoord
Not charging or does not turn on, It might be a battery problem, usually these speakers have a battery that starts to loose capacity in about 2 to 3 years, and if you are a frequent user, then it can last even less... If the battery is not capable of storing power, it may be the reason for which you cannot turn it on or charge it.
Hope it helps.
Luisgomes999 - Antwoord
hi why my jbl don't want to get full charge?
Joshua Flores - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 57
Afgelopen 30 dagen: 255
Altijd: 26,711
