Inleiding
This guide can be used to replace your USB ports and aux cable.
Wat je nodig hebt
Flip the device so the bottom is facing you.
Remove the bottom pad with a nylon or metal spudger.
Slide the ribbon gently out of the connector.
What the name of the white ribbon and where can i buy another mine on my jbl got damaged
From where can I get the micro usb port. Its broken…or what's its called?
17 andere personen hebben deze handleiding voltooid.
15 opmerkingen
Hi! I need the mini usb piece but I don´t know were I can buy it, it is not like the mobile one´s! Please help me!
Thanks
I think it is not normal, if you can find it please contact me! Thanks
need the micro-usb aswell
My jbl charge 2+ is different, after removing the plastic thing in step one there aren't any screws
[|same too at mine :-(]
Eki mako -
I tried step one and was only able to peel off the rubber base exposing the double sided tape. I do not see the cover as shown in step 2. Any help is greatly appreciated. Thanks!
Same case here… :-(
Eki mako -
Buy online 100% fit http://bit.ly/2wxk2GC
How can i make the sound come back?
where do i get the part?!?!? Torn down the speaker allrdy..
The easiest thing is to replace the whole circuit board, I’d try ebay and get something like this https://www.ebay.com/itm/JBL-CHARGE-2-SP...
Has anyone tried to install a USB-C in a JBL Charge 2+?
