Ga door naar hoofdinhoud
JBL Charge 2 Plus Bottom USB Ports and Aux Port Replacement
Wat je nodig hebt
  1. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement, Bottom usb ports and  aux port: stap 1, afbeelding 1 van 1
    • Flip the device so the bottom is facing you.
    • Remove the bottom pad with a nylon or metal spudger.
  2. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: stap 2, afbeelding 1 van 2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: stap 2, afbeelding 2 van 2
    • Remove the 4 screws that hold the white cover.
  3. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: stap 3, afbeelding 1 van 1
    • Slide under the cover and remove it.
  4. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: stap 4, afbeelding 1 van 2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: stap 4, afbeelding 2 van 2
    • Remove the one screw holding the circuit board.
  5. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: stap 5, afbeelding 1 van 1
    • Pry the board with the plastic opening tool.
  6. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: stap 6, afbeelding 1 van 2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: stap 6, afbeelding 2 van 2
    • Slide the ribbon gently out of the connector.
Conclusie
17 andere personen hebben deze handleiding voltooid.
John Reynolds
3.134 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 4-1, Catania Fall 2015 Lid van UMass Dartmouth, Team 4-1, Catania Fall 2015
UMASSD-CATANIA-F15S4G1
4 Leden
12 handleidingen geschreven
15 opmerkingen
Hi! I need the mini usb piece but I don´t know were I can buy it, it is not like the mobile one´s! Please help me!
Thanks
Clash Ofclans - Antwoord
Just having the same issue with the internally broken micro-usb connector. Is it standard, or something special? Thanks!
egyusza - Antwoord
I think it is not normal, if you can find it please contact me! Thanks
I also need to replace my usb connector, has anyone found out where to get one?
Rick - Antwoord
need the micro-usb aswell
hellgrenmicke - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 56
Altijd: 26,780
