Ga door naar hoofdinhoud
JBL Charge 2 Motherboard Replacement
Wat je nodig hebt
  1. JBL Charge 2 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the screen cover from the speaker using a metal spudger.
  2. JBL Charge 2 Motherboard Replacement: stap 2, afbeelding 1 van 2 JBL Charge 2 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
    • Remove the end cap of the device. Repeat the same process to remove the other end cap.
  3. JBL Charge 2 Motherboard Replacement: stap 3, afbeelding 1 van 2 JBL Charge 2 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
    • Twist off the end cap and remove them from the device.
  4. JBL Charge 2 Motherboard Replacement: stap 4, afbeelding 1 van 2 JBL Charge 2 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
    • Pry away the plastic battery cover with a plastic spudger.
  5. JBL Charge 2 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
  6. JBL Charge 2 Motherboard Replacement: stap 6, afbeelding 1 van 3 JBL Charge 2 Motherboard Replacement: stap 6, afbeelding 2 van 3 JBL Charge 2 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
    • Slide the battery free.
  7. JBL Charge 2 Motherboard Replacement, Speakers: stap 7, afbeelding 1 van 1
    • Remove the opposite screen cover using a metal spudger
  8. JBL Charge 2 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Use the Phillips #1 screwdriver (PH1) to remove the (8) eight screws.
    • Pull out the speakers from the device.
  9. JBL Charge 2 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Disconnect the wiring from the speaker by using the fine tip pry tool.
    • Remove the speakers from the device.
  10. JBL Charge 2 Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Use a spudger to disconnect the gold antenna connector from the main circuit board.
  11. JBL Charge 2 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Disconnect the microphone connector using the plastic opening tool.
  12. JBL Charge 2 Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Use a plastic opening tool to disconnect the 3.5 mm headphone connector.
  13. JBL Charge 2 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Disconnect micro-b connector with a plastic opening tool.
  14. JBL Charge 2 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Remove the connector to the USB connector using a plastic opening tool.
  15. JBL Charge 2 Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Remove the speaker wires from the control panel by prying off with a plastic opening tool.
  16. JBL Charge 2 Motherboard Replacement: stap 16, afbeelding 1 van 1
    • Next, disconnect the control-panel ribbon by prying out the grey plastic tab using a plastic opening tool. The ribbon should freely come out afterwards.
  17. JBL Charge 2 Motherboard Replacement: stap 17, afbeelding 1 van 3 JBL Charge 2 Motherboard Replacement: stap 17, afbeelding 2 van 3 JBL Charge 2 Motherboard Replacement: stap 17, afbeelding 3 van 3
    • Caution: Touching the capacitors will short out the circuit board. Push on the end of the circuit board and carefully keep thumbs on foam insulation on ends of board.
    • Remove the motherboard from the device.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Mauzor Ilonzo
495 Reputatie
3 handleidingen geschreven
USF Tampa, Team S2-G4, Passmore Fall 2017 Lid van USF Tampa, Team S2-G4, Passmore Fall 2017
USFT-PASSMORE-F17S2G4
4 Leden
8 handleidingen geschreven
2 opmerkingen
Guten Tag
Vielen Dank für die prima Anleitung!
Ich habe den Fehler bei meinem Charge 2+ gefunden. Das Bauteil mit der 100 drauf ist außen mehrfach gerissen. Was ist das für ein Bauteil und kann ich das bestellen?
Liebe Grüße
Stefan
Stefan Erb - Antwoord
Hello i have a problem with component 100 but i don't now what is ? someone can help me thanks and from were can i order ?
naskicha_94 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 60
Altijd: 8,334
