Ga door naar hoofdinhoud
Ivation IVWPDC20Y Lens Assembly Replacement
Wat je nodig hebt
  1. Ivation IVWPDC20Y Lens Assembly Replacement, Lens Assembly: stap 1, afbeelding 1 van 1
    • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
  2. Ivation IVWPDC20Y Lens Assembly Replacement: stap 2, afbeelding 1 van 1
    • Apply a plastic opening tool to each of the corners and gently remove the casing
    • The front casing is held down by adhesive and may require additional work to remove
    • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
  3. Ivation IVWPDC20Y Lens Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
  4. Ivation IVWPDC20Y Lens Assembly Replacement: stap 4, afbeelding 1 van 1
    • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
    • These screws are very small and easy to strip so apply consistent pressure when removing them
  5. Ivation IVWPDC20Y Lens Assembly Replacement: stap 5, afbeelding 1 van 1
    • Pry off back outer casing using the black spudger or the blue prying tools
  6. Ivation IVWPDC20Y Lens Assembly Replacement: stap 6, afbeelding 1 van 1
    • Carefully remove the screen from the silver casing using a prying tool or the black spudger
    • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
  7. Ivation IVWPDC20Y Lens Assembly Replacement: stap 7, afbeelding 1 van 1
    • Using the poker end of the spudger push gently on the black pegs holding the orange tape in place
    • Screen and orange tape should slip out as a whole
  8. Ivation IVWPDC20Y Lens Assembly Replacement: stap 8, afbeelding 1 van 1
    • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
  9. Ivation IVWPDC20Y Lens Assembly Replacement: stap 9, afbeelding 1 van 1
    • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver
  10. Ivation IVWPDC20Y Lens Assembly Replacement: stap 10, afbeelding 1 van 1
    • Gently lift the corner of the motherboard out
    • Everything should come out as one component free of the casing
  11. Ivation IVWPDC20Y Lens Assembly Replacement: stap 11, afbeelding 1 van 1
    • Remove the two screws holding the lens assembly to the motherboard using the PH00 bit screwdriver
  12. Ivation IVWPDC20Y Lens Assembly Replacement: stap 12, afbeelding 1 van 1
    • Remove the soldering on the 3 wires that are connected to the lens unit
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jack Schlandt
197 Reputatie
1 Handleiding geschreven
USF Tampa, Team 6-6, Eyestone Spring 2016 Lid van USF Tampa, Team 6-6, Eyestone Spring 2016
USFT-EYESTONE-S16S6G6
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 287
