Inleiding
To replace the Circuit Board on an Interlink VP4550 wireless presenter remote requires only 6 easy steps. The Circuit Board controls all of the functions in the remote therefore can be the reason for an unresponsive remote. This guide will show you how to replace the circuit board in the safest and easiest way possible. Below is a step-by-step process on how to disassemble the remote, install the circuit board, and reassemble it all.
Wat je nodig hebt
Turn the phone over to where the battery compartment resides.
Remove the battery compartment door by pushing down on the door with your thumbs and sliding the door off of the bottom of the device.
Remove battery.
Use a Phillips #0 head screwdriver to remove two screws; one on either side of the circuit board.
