Ga door naar hoofdinhoud
Inter-tel IP 8660 LCD Screen Replacement
Wat je nodig hebt
  1. Inter-tel IP 8660 LCD Screen Replacement, Rear Cover: stap 1, afbeelding 1 van 1
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Inter-tel IP 8660 LCD Screen Replacement: stap 2, afbeelding 1 van 3 Inter-tel IP 8660 LCD Screen Replacement: stap 2, afbeelding 2 van 3 Inter-tel IP 8660 LCD Screen Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Inter-tel IP 8660 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Lift up the back cover and set it aside.
  4. Inter-tel IP 8660 LCD Screen Replacement, Internal speaker: stap 4, afbeelding 1 van 1
    • While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
  5. Inter-tel IP 8660 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Lift up the speaker.
  6. Inter-tel IP 8660 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 1 van 3 Inter-tel IP 8660 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 2 van 3 Inter-tel IP 8660 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 3 van 3
    • Lift up the motherboard out of its housing in the front cover of the phone.
    • Set the front cover and button pads aside.
  7. Inter-tel IP 8660 LCD Screen Replacement: stap 7, afbeelding 1 van 3 Inter-tel IP 8660 LCD Screen Replacement: stap 7, afbeelding 2 van 3 Inter-tel IP 8660 LCD Screen Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, pinch the highlighted connective clips together and depress. Start with the clips in the middle of the motherboard first.
    • Note: There are four clips, one at each corner of the LCD screen.
  8. Inter-tel IP 8660 LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Flip the motherboard over so that the LCD screen is facing upward.
  9. Inter-tel IP 8660 LCD Screen Replacement: stap 9, afbeelding 1 van 2 Inter-tel IP 8660 LCD Screen Replacement: stap 9, afbeelding 2 van 2
    • Push the black clip holding the ribbon cable out of its casing using the plastic opening tool.
    • This is done using the spudger to lift one side out of its housing.
    • Reposition the spudger to the other side of the black clip and push it flush with the other end.
    • Note: The black clip pushes out of the housing and does not come completely loose.
  10. Inter-tel IP 8660 LCD Screen Replacement: stap 10, afbeelding 1 van 3 Inter-tel IP 8660 LCD Screen Replacement: stap 10, afbeelding 2 van 3 Inter-tel IP 8660 LCD Screen Replacement: stap 10, afbeelding 3 van 3
    • Pull gently on the ribbon cable so that it comes loose from the black clip.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Juan David GutierrezFranco
67 Reputatie
4 handleidingen geschreven
Cal Poly, Team 11-24, Maness Winter 2012 Lid van Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 858
