Ga door naar hoofdinhoud
Intempo Wireless Speaker Complete Disassembly
Wat je nodig hebt
  1. Intempo Wireless Speaker Complete Disassembly, Intempo Wireless Speaker Complete Disassembly: stap 1, afbeelding 1 van 1
    • Squeeze latch, tilt and remove battery cover to retrieve the batteries.
  2. Intempo Wireless Speaker Complete Disassembly: stap 2, afbeelding 1 van 2 Intempo Wireless Speaker Complete Disassembly: stap 2, afbeelding 2 van 2
    • Pry the top 2 pads to reveal screws using a flat head screwdriver.
  3. Intempo Wireless Speaker Complete Disassembly: stap 3, afbeelding 1 van 3 Intempo Wireless Speaker Complete Disassembly: stap 3, afbeelding 2 van 3 Intempo Wireless Speaker Complete Disassembly: stap 3, afbeelding 3 van 3
    • Unscrew the 5 screws (9 effective threads each) using Phillips 0 head screwdriver.
  4. Intempo Wireless Speaker Complete Disassembly: stap 4, afbeelding 1 van 1
    • Pry up the battery case from the main part using flat head screwdriver.
    • Be careful not to damage the sides of the speaker when prying with the screwdriver.
  5. Intempo Wireless Speaker Complete Disassembly: stap 5, afbeelding 1 van 3 Intempo Wireless Speaker Complete Disassembly: stap 5, afbeelding 2 van 3 Intempo Wireless Speaker Complete Disassembly: stap 5, afbeelding 3 van 3
    • Unscrew the 3 screws (with 9 effective threads each) using Phillips 1 head screwdriver.
    • Lift the circuit board out from the main part.
  6. Intempo Wireless Speaker Complete Disassembly: stap 6, afbeelding 1 van 3 Intempo Wireless Speaker Complete Disassembly: stap 6, afbeelding 2 van 3 Intempo Wireless Speaker Complete Disassembly: stap 6, afbeelding 3 van 3
    • Loosen the glue holding the speaker on the case using the Lever Prybar.
    • Slide the speaker upwards to detach them.
    • Prying the speaker from the case might cause aesthetic damage.
    • Be careful not to break the connections of the speaker wires.
Eindstreep
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 1,022
