Ga door naar hoofdinhoud
Instax Mini 90 Battery Contact Replacement
Wat je nodig hebt
  1. Instax Mini 90 Battery Contact Replacement, Battery: stap 1, afbeelding 1 van 2 Instax Mini 90 Battery Contact Replacement, Battery: stap 1, afbeelding 2 van 2
    • The battery compartment can be found on the backside of the camera. Pinpoint this compartment and focus on the right edge of the compartment gate to find the opening latch.
  2. Instax Mini 90 Battery Contact Replacement: stap 2, afbeelding 1 van 2 Instax Mini 90 Battery Contact Replacement: stap 2, afbeelding 2 van 2
    • Pinch the latch in towards the battery compartment gate. This will release the gate and allow it to open.
    • Completely open the gate and remove from camera. Take out the battery and replace the gate.
  3. Instax Mini 90 Battery Contact Replacement, Battery Contact: stap 3, afbeelding 1 van 3 Instax Mini 90 Battery Contact Replacement, Battery Contact: stap 3, afbeelding 2 van 3 Instax Mini 90 Battery Contact Replacement, Battery Contact: stap 3, afbeelding 3 van 3
    • Turn camera around to its backside.
    • Open up the back side of the camera by pushing up on the slide button. This button is located on the middle left side of the camera.
  4. Instax Mini 90 Battery Contact Replacement: stap 4, afbeelding 1 van 1
    • Use the Phillips #000 Screwdriver to remove the five 3.5 mm screws located in the backside door of the camera.
  5. Instax Mini 90 Battery Contact Replacement: stap 5, afbeelding 1 van 3 Instax Mini 90 Battery Contact Replacement: stap 5, afbeelding 2 van 3 Instax Mini 90 Battery Contact Replacement: stap 5, afbeelding 3 van 3
    • Remove the black plastic piece on top, then remove the thin, metal piece. This metal piece is the battery contact.
    • Replace the battery contact with the new one.
Conclusie
Elliott Tegan-Tawney
690 Reputatie
5 handleidingen geschreven
USF Tampa, Team S2-G1, Nance Spring 2017 Lid van USF Tampa, Team S2-G1, Nance Spring 2017
USFT-NANCE-S17S2G1
4 Leden
12 handleidingen geschreven
Één opmerking
This guide only removes the battery tray. The contacts are visible in the last pic of the last step, still in place, under the red wire
John Doe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 44
Altijd: 4,061
