Ga door naar hoofdinhoud
Instax Mini 90 Film Cartridge Replacement
Wat je nodig hebt
  1. Instax Mini 90  Film Cartridge Replacement, Film Cartridge: stap 1, afbeelding 1 van 1
    • Turn ON the camera, and flip it over so that the back cover is visible.
  2. Instax Mini 90  Film Cartridge Replacement: stap 2, afbeelding 1 van 3 Instax Mini 90  Film Cartridge Replacement: stap 2, afbeelding 2 van 3 Instax Mini 90  Film Cartridge Replacement: stap 2, afbeelding 3 van 3
    • Unlock the back cover. It should automatically spring open. If there is an old film cartridge loaded in the camera, remove it.
  3. Instax Mini 90  Film Cartridge Replacement: stap 3, afbeelding 1 van 3 Instax Mini 90  Film Cartridge Replacement: stap 3, afbeelding 2 van 3 Instax Mini 90  Film Cartridge Replacement: stap 3, afbeelding 3 van 3
    • Unwrap the new film cartridge, taking care to not touch the film inside. Only handle the film cartridge by its plastic shell.
    • Line up the small, yellow line on the cartridge with the corresponding yellow line inside the camera. The yellow line on the cartridge should be facing up, away from the camera.
  4. Instax Mini 90  Film Cartridge Replacement: stap 4, afbeelding 1 van 2 Instax Mini 90  Film Cartridge Replacement: stap 4, afbeelding 2 van 2
    • Close the back cover. The film covering should eject automatically.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Elliott Tegan-Tawney
690 Reputatie
5 handleidingen geschreven
USF Tampa, Team S2-G1, Nance Spring 2017 Lid van USF Tampa, Team S2-G1, Nance Spring 2017
USFT-NANCE-S17S2G1
4 Leden
12 handleidingen geschreven
5 opmerkingen
Having an issue with the film pack not loading. Have tried resetting, removing battery etc. Any ideas?
Lawrence Cassel - Antwoord
Me too! Ive removed battery, replaced with fresh battery, nothing happens! Ive just used it once! Help!!
susan ahrent - Antwoord
I’m having the same problem and I’ve tried everything. Someone help! The film simply isn’t being recognized (no blinking E or anything like that).
ap5029 - Antwoord
I am not too sure how to fix that, but definitely try contacting Fujifilm, as they know much more about their products and do repairs as well! https://www.fujifilmusa.com/support/Serv...
Elliott Tegan-Tawney - Antwoord
I have a fujifilm instax mini evo hybrid black instant camera but it does not detect film. The message of putting a new cartridge keeps popping-up. Do you know what could be the cause?
Herman Saldana - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 136
Altijd: 20,206
