Ga door naar hoofdinhoud
Instant Pot Smart-60 Plastic Base Replacement
Wat je nodig hebt
  1. Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: stap 1, afbeelding 1 van 2 Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: stap 1, afbeelding 2 van 2
    • Take off the lid of the Instant Pot. Grasp the handle and rotate the lid counter-clockwise, then lift up to separate the lid from the base.
  2. Instant Pot Smart-60 Plastic Base Replacement: stap 2, afbeelding 1 van 1
    • Take out the inner pot and place it somewhere out of the way.
  3. Instant Pot Smart-60 Plastic Base Replacement: stap 3, afbeelding 1 van 1
    • Flip the Instant Pot over on its top so that the base is facing upward.
  4. Instant Pot Smart-60 Plastic Base Replacement: stap 4, afbeelding 1 van 1
    • Remove the single 12mm Phillips #2 screw holding the base to the device.
  5. Instant Pot Smart-60 Plastic Base Replacement: stap 5, afbeelding 1 van 1
    • Rotate the base counter-clockwise, then gently lift the base off of the device.
Conclusie
3 andere personen hebben deze handleiding voltooid.
paola alvarez
534 Reputatie
4 handleidingen geschreven
Cal Poly, Team S1-G4, Livingston Winter 2018 Lid van Cal Poly, Team S1-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G4
4 Leden
6 handleidingen geschreven
13 opmerkingen
Hi, I would like to know, where can I buy a new plastic base? Thank you
nathaliawed - Antwoord
Hello where can I buy the plastic base
Maureen - Antwoord
I would like to buy one of these for an 8 Qt model….very hard to source this and terrible customer support as this seems to be a issue for many that burned theirs.
davidghamilton - Antwoord
Did you ever find out where you can buy this part.
Thank you. Belinda
Belinda Berka - Antwoord
Do you carry the replacement for this. Thanks
khai01 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 35
Altijd: 6,679
