Ga door naar hoofdinhoud
Instant Pot IP-DUO80 V2 LED Display Replacement
Wat je nodig hebt
  1. Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: stap 1, afbeelding 1 van 3 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: stap 1, afbeelding 2 van 3 Instant Pot IP-DUO80 V2 LED Display Replacement, LED Display: stap 1, afbeelding 3 van 3
    • Open the lid by turning it counter-clockwise and lifting up.
    • Remove the inner pot.
  2. Instant Pot IP-DUO80 V2 LED Display Replacement: stap 2, afbeelding 1 van 3 Instant Pot IP-DUO80 V2 LED Display Replacement: stap 2, afbeelding 2 van 3 Instant Pot IP-DUO80 V2 LED Display Replacement: stap 2, afbeelding 3 van 3
    • Turn the Instant Pot upside down.
    • Remove the single 12-mm screw by using the T-15 head screwdriver and turning it counter-clockwise.
    • Turn the plate counter-clockwise and lift it off the Instant Pot.
  3. Instant Pot IP-DUO80 V2 LED Display Replacement: stap 3, afbeelding 1 van 2 Instant Pot IP-DUO80 V2 LED Display Replacement: stap 3, afbeelding 2 van 2
    • Remove the three 19-mm screws in the black plastic base's edge using the PH-1 head screwdriver and twisting counter-clockwise.
  4. Instant Pot IP-DUO80 V2 LED Display Replacement: stap 4, afbeelding 1 van 2 Instant Pot IP-DUO80 V2 LED Display Replacement: stap 4, afbeelding 2 van 2
    • Pull the power cord out of its slot.
    • Pull up on the edge of the black plastic base to remove the base.
  5. Instant Pot IP-DUO80 V2 LED Display Replacement: stap 5, afbeelding 1 van 3 Instant Pot IP-DUO80 V2 LED Display Replacement: stap 5, afbeelding 2 van 3 Instant Pot IP-DUO80 V2 LED Display Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the two green-striped yellow wires that are connected onto the bottom of the heating element. Use a PH-1 head screwdriver and turn counter-clockwise to remove the 10-mm screw holding them in place.
    • Be careful not to lose the small washer that comes with this screw.
    • Pull up on the cn101 connection to detach the LED display from the motherboard.
  6. Instant Pot IP-DUO80 V2 LED Display Replacement: stap 6, afbeelding 1 van 1
    • Lift the silver outer shell off of the top black ring.
  7. Instant Pot IP-DUO80 V2 LED Display Replacement: stap 7, afbeelding 1 van 3 Instant Pot IP-DUO80 V2 LED Display Replacement: stap 7, afbeelding 2 van 3 Instant Pot IP-DUO80 V2 LED Display Replacement: stap 7, afbeelding 3 van 3
    • Remove the two 10-mm screws connecting the LED display to the outer shell using a PH-1 head screwdriver and twisting counter clockwise.
    • Pull out the LED display by pulling on it gently.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Kayla Meacham
630 Reputatie
5 handleidingen geschreven
Cal Poly, Team S18-G2, Livingston Winter 2018 Lid van Cal Poly, Team S18-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G2
4 Leden
10 handleidingen geschreven
2 opmerkingen
Where can I get the replacement for the display?
Starfish Doodle - Antwoord
Hola disculpa, donde puedo conseguir la pantalla led de mi instat pot DUO PLUS MULTI-COOKER 9in 1
Evaristo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 55
Altijd: 6,284
