Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Lay your iMac front side down on a table with the lower edge facing yourself.
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
Gereedschap gebruikt in deze stap:Heavy-Duty Suction Cups (Pair)$14.95-
Stick two suction cups to opposing corners of the glass panel.
Gently pull the glass panel straight up off the iMac.
Remove the following 12 screws securing the front bezel to the rear case:
Eight 13 mm T8 Torx.
Four 25 mm T8 Torx.
Gently lift the front bezel from its top edge off the rear case.
Once the top edge of the front bezel has cleared the rear case, rotate the front bezel toward the stand and lift it off the rear case.
Rotate the front bezel away from the rest of the device and lay it above the top edge of the iMac.
Disconnect the microphone cable connector, removing tape as necessary.
Pull the LCD temperature sensor connector straight up off its socket on the logic board.
(located at the top of the logic board on the 24")
Remove the two T6 Torx screws securing the display data cable to the logic board.
Use the attached black tab to pull the display data cable connector straight away from the logic board.
Remove the eight T8 Torx screws securing the display panel to the rear case.
Lift the display panel from its left edge and rotate it toward the right edge of the iMac.
With the display panel still lifted, disconnect the four inverter cables.
(combined into one plug in on the 24")
Peel the strip of EMI tape off the edge of the rear case.
Remove the two T10 Torx screws securing the optical drive to the rear case.
If necessary, remove the piece of tape holding the thermal sensor wires to the hard drive.
Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
When removing this connector, it is helpful use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
Lift the left edge of the optical drive slightly and pull it away from the right side of the rear case.
Insert a spudger between the optical drive connector and the optical drive.
Twist the spudger to slightly separate the optical drive connector from the optical drive, then use your fingers to pull the connector away from the drive.
Remove the piece of foam tape covering the optical drive thermal sensor.
To remove the optical drive thermal sensor, use the tip of a spudger to lift the center finger of the thermal sensor bracket while applying slight tension to the thermal sensor cable.
Use the flat end of a spudger to pry the optical drive thermal sensor bracket up off the adhesive securing it to the optical drive.
Use a spudger to remove the small piece of EMI foam from the bottom of the optical drive.
Remove the two T10 Torx screws from both sides of the optical drive (four screws total).
Use the tip of a spudger to press each of the optical drive bracket tabs out of their slots on the bottom of the optical drive.
Rotate the optical drive bracket slightly away from the optical drive.
Pull the optical drive bracket away from the open end of the optical drive, minding any tabs that may get caught.
Remove the three 3.0 mm Phillips screws from the optical bay enclosure.
Starting from the left edge, gently pull open the optical bay enclosure.
Continue to pull open the two halves of the enclosure until they separate.
Remove the two 3.0 mm Phillips screws securing the faceplate to the optical bay enclosure.
Lift the black plastic faceplate out of the optical bay enclosure.
Reassemble the optical bay enclosure without the faceplate, reusing the original three 3.0 mm Phillips screws to keep it intact.
Remove the plastic positioner from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
Make sure that the hard drive connectors are facing down before placing it into the enclosure.
Gently place the hard drive into the enclosure's hard drive slot.
While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
Once the hard drive is snug, reinsert the plastic positioner while holding the hard drive against the bottom of the enclosure.
Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
18 andere personen hebben deze handleiding voltooid.
