Inleiding
There are many benefits to adding a second hard drive to your laptop such as improved speeds, greater storage space, and less heartache when installing new software. Use this guide to install one using our optical bay hard drive enclosure.
Wat je nodig hebt
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Gereedschap gebruikt in deze stap:P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery
Three Pentalobe screws secure the battery to the upper case. They can be removed with this special driver.
Unfortunately, when I added a second hard drive via these instructions, all went well but Bluetooth is now MIA. Can anyone help?
I agree...
I have bought a used MacBook Pro, when problems arise, opening Corps was trying to turn the screw, but with poor quality could not turn a screwdriver, only to ruin the screw. Try to buy ifixit Screwdriver set. Good luck to all and thank you ifixit team for such assistance as ifixit.com. Thank you.
Remove the two exposed five-point Pentalobe screws along the top edge of the battery.
I have a problem with these screw. They a completly warn and I need some new ones to fix the new Battery.
Does anyone know which thread it is and which length?
Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
I tried to move the plastic piece, but it seemed risky for someone with no experience like me. It was not hard at all to just peel off the camera cable without messing with the connector, and then, carefully take the optical drive out.
Totally agree. Optical drive is easily removed by peeling off camera cable
Remove the optical drive cable by pulling it straight away from the optical drive.
Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
Remove the plastic spacer from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
All Macbooks use 9.5mm Optical Drive Caddy, also, If you’re wondering as well, the Optical Drive runs at SATA II speeds just like with the main hard drive area, so if you’re using a SSD, then it’s going to run at a slightly slower speed.
Make sure that the hard drive connectors are facing down before placing it into the enclosure.
Gently place the hard drive into the enclosure's hard drive slot.
While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
Okay it seems like some models of MacBook Pro have issues with a fast (6Gbit/s) SSD in the optical bay. Even though my Mac says it offers 6Gbit on both bays it simply didn't work in the optical bay. So I switched places between the two drives and everything seems to work. My Mac booted from the old HDD in optical bay automatically and then I cloned it afterwards and changed the startup disk to the new one. As said before, don't put a fast SSD in the optical bay!
This is an extremely late response to an old comment, but… whatev’s. My 2011 MacBook Pro had that issue: the main (HDD bay) SATA operated at 6Gbit, and while the optical bay said it was 6Gbit, the “Negotiated Link Speed” was like 1.5Gbits regardless of what you put in it (I can understand 1.5Gbits for an optical drive, but not for an SSD). Some of the early 2012 models did the same thing, from what I understand, but that was corrected pretty early on; both my 13” and 15” 2012’s run at 6Gb/s on both SATA busses.
AJH -
It’s not wise to swop the optidrive for an HD as there is no physical protection. The caddy is only intended for an SSD.
Once the hard drive is snug, reinsert the plastic spacer while holding the hard drive against the bottom of the enclosure.
Use two Phillips #1 screws to secure the drive to its enclosure.
Where are these screws coming from? Were they part of the original optical drive?
The new enclosure should include these two Phillips screws.
Can someone show the step of removal process of hdd/SSD placed in the caddy? I am unable to revert this process. Do we have to apply back greater force to remove back the hard drive/SSD from the caddy?
These screws seems to be located in different places on different enclosures. I had serious trouble getting the SSD that the previous owner of this MacBook installed out of the enclosure until I realized the screws holding the SSD in place were on the side and not on the bottom. In case anyone else has the same issue!
Attach the optical drive bracket to the new enclosure with two Phillips #0 screws.
Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
Replaced the optical with hdd, as well as replaced the hard drive with an ssd. Now I get the circle with a line through it. But, when I hold the option key down, it gives me both hard drives, PLUS, the thumb drive I have in the USB port with a Mountain Lion installer. It even shows the recovery disks, but gives me the circle with the line when I choose one. Any help is appreciated.
Mate,
My mbp shipped with OS 10.8, and I had upgraded twice to 10.10
I've a 10.7 USB which upgraded my old MBP.
My plan today was to boot with my new ssd, my time machine back up and the Lion usb plugged in.
I would then click on the Lion usb, and tell it to put the OS and time machine back up on the ssd.
So I help down ALT and when it started it gave me the options of the usual Mac internal or the Lion USB.
I clicked Lion, but instead of taking me to the install options (Disk utility, restore from time machine etc etc) it gave me that grey circle with a diagonal line through it. The no entry sign - grey on grey - that I think you have.
Some googling said that it is because I was trying to usb a 10.7 install on a MBP that shipped 10.8
You can't go back, apparently.
So if any of the OSs are older than the mac you got, you will get this error. The grey in grey no entry.
I just cloned my HDD to my ssd (Carbon copy cloner free 30 day trial) using an external stat-usb3 wire and all is good.
Rory -
I have a 17" Macbook Pro6,1 unibody with an Intel Core i5, 2.53GHz. I was successful installing a 250GB SSD in the DVD bay, and I'm able to boot from it. I did this by first installing OS X 10.9.4 on the SSD mounted into an external HD case, testing the system to see if it would boot up into the SSD, then installing the SSD and carrier in the DVD drive bay. The system now boots up from the SSD with no problems. If you are having installation problems, I recommend trying this method.
I just have finished installing second SSD to my MBP (unibody 15` 2010).
First one was changed like one year ago. Samsung 500GB SSD. It is in my HDD bay and I'm running system from it.
Today I put a new Samsung 1TB 850 Evo 1 SSD in to my optic bay.
I encounter problem with SSD not recognized by Finder.
But It was recognized by Disk Utility.
What I did was I erase new SSD by Disk Utility. Then the new partition was created and now It has been seen by Finder.
So If you see it in Disk Utility just erased it.
Some extra info in under this link--> https://discussions.apple.com/docs/DOC-4...
Wish you all luck :)
My installation went great thanks to the guide. I did notice a small thing that might make a good tip, and that is to inspect all the visible screws. I saw one that was slightly raised, and when I poked around with the spudger, I found 2 more that had worked themselves out a bit. Its probably something super rare but at the age of these things, it wouldn't hurt to check.
Align the cable's SATA connector with the drive's port and plug in securely.
Plug the USB connector into your laptop and your optical drive is ready for use.
There is a small metal button in the front of the drive and you can use that to eject the drive if you were wondering.
Maybe that explain the eject button mechanism maybe….
Die neue SSD wurde durch das Laufwerk ersetzt aber leider wird jetzt die alte HDD nicht mehr erkannt. Hatte schon ein anderer das Problem?
51 andere personen hebben deze handleiding voltooid.
