Inleiding
L'accesso alla memoria RAM e il relativo aggiornamento sono operazioni semplici.
  1. Premere con le dita entrambe le linguette di sgancio della batteria verso l'esterno e sollevare la batteria dal computer. Premere con le dita entrambe le linguette di sgancio della batteria verso l'esterno e sollevare la batteria dal computer. Premere con le dita entrambe le linguette di sgancio della batteria verso l'esterno e sollevare la batteria dal computer.
    • Premere con le dita entrambe le linguette di sgancio della batteria verso l'esterno e sollevare la batteria dal computer.
    Before start, make a clone of your old HD into the new one, if you don't want to initiate a fresh copy. (Carbon Copy software is good).
    ColmillodeChile - Antwoord
    Besides using WD 500GB models, are the WD 640GB and WD 750GB (the 9.5mm thickness model) good to go for? I am still considering as I have heard from other websites on the computer does not draw enough power to power up the 640 and 750 as it has the clicking sound and the rainbow keeps appearing. Anyone has install one before yet?
    Please advice. Appreciated! Thanks a million to all the Mac gurus out there!
    Danny Lim -
    Citaat van ColmillodeChile:
    What is this about removing the PRAM battery causing a reinitialization of the HDD? For serious?
    Adrian - Antwoord
    No, that's nonsense
    max damage -
    Citaat van Adrianthomaspre:
    Wait, I misunderstood you. I thought the comment was directed at the PRAM battery removal page. Silly me.
    Nevermind. Yes, it is always a good idea to backup one's data before doing stuff like this. I never do, and have never had any problems, but it's still a good idea.
    Adrian - Antwoord
    The two screws removed in step 3 should not be mixed with screws in steps 5 through 7. Though similar, they are actually slightly shorter and have a bigger head. If you put the longer screws back in here when reassembling, the button to unlatch the top will not work properly.
    Doug - Antwoord
    Citaat van Doug:
    I think you may have commented on the wrong page. This page only has 3 steps, and the screws are removed in step 2, not 3.
    (MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement)
    Don - Antwoord
    I'm not sure how the user notes get attached to the various procedures here, but my comment does seem to show up properly when viewing the steps for Hard Drive Replacement. However, the number of the step may be off if viewed as part of another procedure.
    Citaat van Don:
    Doug - Antwoord
  2. Android Fix Kits
    Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
  3. Rimuovere le tre viti con testa a croce da 2 mm dallo sportello della memoria. Sollevare lo sportello della memoria affinché sia possibile prenderlo e farlo scorrere verso di sé, estraendolo dall'alloggiamento.
    • Rimuovere le tre viti con testa a croce da 2 mm dallo sportello della memoria.
    • Sollevare lo sportello della memoria affinché sia possibile prenderlo e farlo scorrere verso di sé, estraendolo dall'alloggiamento.
    These screws are different from the rest, they should be kept separate from the others.
    Maarten Van Coile - Antwoord
    Replacing RAM on an A1226: The instructions said Phillips #00, but the screwdriver that fit the RAM Shield screws for me was a Phillips #0.
    dlyons - Antwoord
  4. Sganciare le linguette sui lati del chip di memoria RAM, premendole contemporaneamente. Queste linguette bloccano il chip in posizione. Sganciandole, il chip "salterà" fuori. Estrarre il chip direttamente dal connettore.
    • Sganciare le linguette sui lati del chip di memoria RAM, premendole contemporaneamente. Queste linguette bloccano il chip in posizione. Sganciandole, il chip "salterà" fuori.
    • Estrarre il chip direttamente dal connettore.
    • Se sono presenti due chip di memoria RAM, ripetere la procedura precedente per il secondo chip.
Conclusie
Per riassemblare il dispositivo, seguire queste istruzioni in ordine inverso.
212 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Jasper Fleischhauer helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Really easy to install RAM on Macbook Pro 15'' Model A1226!!
I had 2GB of RAM (1GB and 1GB), so when I read this tutorial I decided to buy one ram of 2GB 667Mhz and It is working great (now I've got a total of 3 GB). I'm willing to install up to 6 GB with this same tutorial. Recommended!
cesrafa - Antwoord
Voeg een opmerking toe
Bekijk statistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 176
Aller tijden: 126,333
