Ga door naar hoofdinhoud
Install the Battery on bObi Pet
Wat je nodig hebt
  1. Install the Battery on bObi Pet, Turn bObi Pet Off: stap 1, afbeelding 1 van 2 Install the Battery on bObi Pet, Turn bObi Pet Off: stap 1, afbeelding 2 van 2
    • Make sure bObi Pet's power switch is turned OFF.
    • Then, flip bObi Pet over onto a flat surface, so the wheels point up.
  2. Install the Battery on bObi Pet, Open the Battery Compartment: stap 2, afbeelding 1 van 3 Install the Battery on bObi Pet, Open the Battery Compartment: stap 2, afbeelding 2 van 3 Install the Battery on bObi Pet, Open the Battery Compartment: stap 2, afbeelding 3 van 3
    • Remove the two screws holding her battery cover in place.
    • Remove the battery cover. Keep the cover and screws close by for the next step.
  3. Install the Battery on bObi Pet, Plug in the New Battery: stap 3, afbeelding 1 van 3 Install the Battery on bObi Pet, Plug in the New Battery: stap 3, afbeelding 2 van 3 Install the Battery on bObi Pet, Plug in the New Battery: stap 3, afbeelding 3 van 3
    • Plug the new battery in at the circuit junction.
    • Tuck the wire into the side of the compartment.
    • Ensure the wires are not in the way, then, slide the battery straight down.
  4. Install the Battery on bObi Pet, Replace the Battery Cover: stap 4, afbeelding 1 van 3 Install the Battery on bObi Pet, Replace the Battery Cover: stap 4, afbeelding 2 van 3 Install the Battery on bObi Pet, Replace the Battery Cover: stap 4, afbeelding 3 van 3
    • Replace the battery cover so that it lies flat.
    • Reinstall the 2 screws to finish the installation process.
Conclusie
After finishing the battery installation correctly, turn bObi Pet's side power switch to ON and your robotic vacuum should be ready to work.
Chelsea
2.278 Reputatie
31 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 159
