Ga door naar hoofdinhoud
Install Windows 10 on the Pixel
Wat je nodig hebt
  1. Install Windows 10 on the Pixel, Get your Pixel ready: stap 1, afbeelding 1 van 1
    • Backup your data before we begin
    • You'll want to prepare a MBR bootable USB 8.1/10 drive using Rufus or the Window 10 installation tool
    • Have an external USB keyboard and mouse ready
  2. Install Windows 10 on the Pixel, Developer mode and USB Boot: stap 2, afbeelding 1 van 3 Install Windows 10 on the Pixel, Developer mode and USB Boot: stap 2, afbeelding 2 van 3 Install Windows 10 on the Pixel, Developer mode and USB Boot: stap 2, afbeelding 3 van 3
    • Enable developer mode and legacy USB boot
    • Boot into ChromeOS
    • You'll get to the developer mode on screen. Press "ctrl" + "L" to boot into the legacy SeaBIOS
  3. Install Windows 10 on the Pixel, Boot into Windows 10: stap 3, afbeelding 1 van 2 Install Windows 10 on the Pixel, Boot into Windows 10: stap 3, afbeelding 2 van 2
    • Plug in your USB keyboard
    • Select the flash drive containing your Windows 10 installation
    • Boot into Windows 10
  4. Install Windows 10 on the Pixel, Prepare your SSD: stap 4, afbeelding 1 van 2 Install Windows 10 on the Pixel, Prepare your SSD: stap 4, afbeelding 2 van 2
    • Use the advanced tools to open up an elevated command prompt
    • Run diskpart and clean the storage on your SSD boot drive
  5. Install Windows 10 on the Pixel, Install Windows 10: stap 5, afbeelding 1 van 3 Install Windows 10 on the Pixel, Install Windows 10: stap 5, afbeelding 2 van 3 Install Windows 10 on the Pixel, Install Windows 10: stap 5, afbeelding 3 van 3
    • Reboot into the Windows installer from your USB drive
    • Click Install Now to install Windows 10
    • Select your SSD as the default install location
  6. Install Windows 10 on the Pixel, Wait a bit...: stap 6, afbeelding 1 van 1
    • Let Windows 10 install
    • Whenever the computer reboots. Press "ctrl" + "L" to get back to the BIOS
  7. Install Windows 10 on the Pixel, Setup Windows: stap 7, afbeelding 1 van 3 Install Windows 10 on the Pixel, Setup Windows: stap 7, afbeelding 2 van 3 Install Windows 10 on the Pixel, Setup Windows: stap 7, afbeelding 3 van 3
    • Follow the on-screen guide to finish installing Windows
    • Wi-Fi and audio should work out of the box, but you'll still need your USB keyboard/mouse to continue with the setup
    • We'll install drivers shortly
    • Cortana will likely be really loud.
    • Plug in a pair of headphones or silence her by clicking the mute button on the bottom right of the screen.
  8. Install Windows 10 on the Pixel, Install drivers & Customize: stap 8, afbeelding 1 van 1
    • Install all of your Windows device drivers (keyboard, trackpad, touchscreen) from Coolstar's webpage
    • https://coolstar.org/chromebook/windows-...
    • Note that drivers may be buggy. You might have to reinstall ChromeOS by using recovery in order to flash/re-flash the BIOS.
    • This is risky business, so only flash it if your drivers don't work out of the box and you have the technical know-how to fix it.
Conclusie
Enjoy running Windows on your Pixel and have the satisfaction that not many have attempted this feat!
18 andere personen hebben deze handleiding voltooid.
Kevin Fessler
1.770 Reputatie
4 handleidingen geschreven
17 opmerkingen
Hello, have you successfully gotten the trackpad to work? Last time I heard Coolstar claimed that this wouldn't be possible.
therealpurplesound - Antwoord
Yup, the track-pad works (mostly) how it supposed to. I just can't post the driver since Mr. Chromebox noted that it's closed source; therefore I've decided to go solo with my work. It's definitely not impossible, just hard to figure out how to use the Intel I2C interface which drives the touchpad. I'd recommend starting your research on the official Intel datasheet for the specification and take a look at the Linux community drivers written in C for inspiration. You should check the Reddit page in case Coolstar or Mr. Chromebox has found a way to circumvent the legality issues or issued a fix of their own.
Kevin Fessler -
Hey did you end up doing this therealpurplesound? I want to do this as well but the trackpad, touchscreen, audio and other basic features that I haven't got a solid answer on stop me.
Josh Chichon -
Does it rotate when you do it?
Technopal V2.0 -
Hi, in a comment above you mention that the touchpad / trackpad mostly works as it's supposed to , but for reasons you cannot link it, can you elaborate on this? Is there a public solution as I am a bit confused and wish to gather more information before going forward.
I just wish to understand if the Pixel 2013 will work (keyboard, touchpad, touchscreen, etc) under Windows 10 as a normal functioning laptop.
Thank you.
Josh Chichon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 231
Altijd: 48,771
