Ga door naar hoofdinhoud
Inspiron 7359 2-in-1 Screen Replacement
Wat je nodig hebt
  1. Inspiron 7359 2-in-1 Screen Replacement, Bottom Case: stap 1, afbeelding 1 van 1
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Screen Replacement: stap 2, afbeelding 1 van 2 Inspiron 7359 2-in-1 Screen Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Screen Replacement: stap 3, afbeelding 1 van 1
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Screen Replacement: stap 4, afbeelding 1 van 1
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Screen Replacement, Screen: stap 5, afbeelding 1 van 1
    • Using a spudger or opening pick, carefully pry in between the screen and the screen backing.
    • After opening the LCD Screen, slowly and carefully open the laptop so the front of the screen touches the keyboard.
  6. Inspiron 7359 2-in-1 Screen Replacement: stap 6, afbeelding 1 van 1
    • Slowly peel back the tape that is attached to the screen itself.
    • Once the tape is removed, gently disconnect the attached cables.
  7. Inspiron 7359 2-in-1 Screen Replacement: stap 7, afbeelding 1 van 1
    • Carefully disconnect the attached cable.
    • Once you remove the attached cable, gently lift up the LCD panel.
Conclusie
Dominique
251 Reputatie
2 handleidingen geschreven
Gateway, Team S1-G3, Saknee Fall 2019 Lid van Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 44
Altijd: 510
