Ga door naar hoofdinhoud
Inspiron 7359 2-in-1 Battery Replacement
Wat je nodig hebt
  1. Inspiron 7359 2-in-1 Battery Replacement, Bottom Case: stap 1, afbeelding 1 van 1
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Battery Replacement: stap 2, afbeelding 1 van 2 Inspiron 7359 2-in-1 Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Battery Replacement: stap 3, afbeelding 1 van 1
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Battery Replacement: stap 4, afbeelding 1 van 1
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Unscrew two 8mm screws with a Phillips #0 screwdriver.
    • Unscrew one silver, wide-head, 8mm screw with a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard.
    • Make sure to keep all screws together and label where you unscrewed them from.
  6. Inspiron 7359 2-in-1 Battery Replacement: stap 6, afbeelding 1 van 1
    • To remove the old battery, lift from the bottom and pull the battery towards you.
Conclusie
To reassemble your device, follow these instructions in reverse order using a new battery.
Alfredo Acosta
141 Reputatie
1 Handleiding geschreven
Gateway, Team S1-G3, Saknee Fall 2019 Lid van Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 53
Altijd: 189
