Ga door naar hoofdinhoud
Insignia Sport NS-4V17 Play/Pause Button Replacement
Wat je nodig hebt
  1. Insignia Sport NS-4V17 Play/Pause Button Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 2, afbeelding 1 van 2 Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 2, afbeelding 2 van 2
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 3, afbeelding 1 van 1
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 4, afbeelding 1 van 1
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Play/Pause Button Replacement, Front Case Cover: stap 5, afbeelding 1 van 2 Insignia Sport NS-4V17 Play/Pause Button Replacement, Front Case Cover: stap 5, afbeelding 2 van 2
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 6, afbeelding 1 van 1
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 7, afbeelding 1 van 3 Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 7, afbeelding 2 van 3 Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 7, afbeelding 3 van 3
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 8, afbeelding 1 van 1
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
  9. Insignia Sport NS-4V17 Play/Pause Button Replacement, Scroll Wheel: stap 9, afbeelding 1 van 1
    • Remove the white plastic ring from around the scroll wheel using your fingers.
  10. Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 10, afbeelding 1 van 3 Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 10, afbeelding 2 van 3 Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 10, afbeelding 3 van 3
    • Insert the plastic opening tool underneath any side of the scroll wheel.
    • Slowly lift up on the plastic opening tool and the scroll wheel will come off.
  11. Insignia Sport NS-4V17 Play/Pause Button Replacement, Play/Pause Button: stap 11, afbeelding 1 van 1
    • Slightly insert plastic opening tool underneath any side of the play button.
  12. Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 12, afbeelding 1 van 2 Insignia Sport NS-4V17 Play/Pause Button Replacement: stap 12, afbeelding 2 van 2
    • Lift up slowly with the plastic opening tool and the play button should pop off.
Conclusie
Wesley Ballar
88 Reputatie
4 handleidingen geschreven
Cal Poly, Team 12-36, Amido Spring 2013 Lid van Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 301
