Ga door naar hoofdinhoud
Insignia NSD9PDVD15 Screen Replacement
Wat je nodig hebt
  1. Insignia NSD9PDVD15 Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Insignia NSD9PDVD15 Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • Slide the “Open” tab on the top of the device.
    • This will allow you to open the device.
  2. Insignia NSD9PDVD15 Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the six Phillips #00 screws from the screen casing.
    • To access two of the screws, first remove 2 small, flat rubber circles from the corners of the screen casing. Use a spudger if necessary.
  3. Insignia NSD9PDVD15 Screen Replacement: stap 3, afbeelding 1 van 1
    • Remove the two screws from the hinge that holds together the screen casing and the disk panel.
    • Abruptly opening the device too wide will break the hinge. To fully access the hinge screws, firmly but gently open the device wider.
  4. Insignia NSD9PDVD15 Screen Replacement: stap 4, afbeelding 1 van 1
    • Insert the plastic opening tool into the rectangular holes and pry open in order to access the interior of the screen casing.
    • Remove the four screws and corresponding washers from the edges of the screen.
    • Use a plastic opening tool to prop open if necessary.
  5. Insignia NSD9PDVD15 Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the eight screws from the green motherboard.
  6. Insignia NSD9PDVD15 Screen Replacement: stap 6, afbeelding 1 van 1
    • Unplug the red wires from the motherboard by gently pulling them off.
    • Then remove the screen.
  7. Insignia NSD9PDVD15 Screen Replacement: stap 7, afbeelding 1 van 1
    • Set the new screen in place.
Conclusie
Jen Rodas
1 Reputatie
1 Handleiding geschreven
Ohio State, Team 2-5, Garvin Fall 2015 Lid van Ohio State, Team 2-5, Garvin Fall 2015
OSU-GARVIN-F15S2G5
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 465
