Wat je nodig hebt
Stap 1 Battery
Voorzichtig: stappen 1-4 komen van een handleiding die in bewerking is.
Remove the rubber sleeve.
Once the battery and back cover have been successfully removed, use the soldering iron. To remove the on/off switch from the circuit board, use a soldering iron to heat previous solders until melted.
Make sure the device is off before you begin your replacement. The device originally comes with an on/off and battery saving mode switch. A soldering iron is extremely hot, so take caution when using this tool. Use tweezers when removing the part because the part will be very hot.
