Ga door naar hoofdinhoud
Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement
Wat je nodig hebt
  1. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the rubber sleeve.
  2. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: stap 2, afbeelding 1 van 2 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: stap 2, afbeelding 2 van 2
    • Use the specified screwdriver to unscrew the ten screws on the back cover.
  3. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: stap 3, afbeelding 1 van 2 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the back cover. Be careful to not lose any of the screws because they are extremely small and can be easily lost.
  4. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: stap 4, afbeelding 1 van 2 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: stap 4, afbeelding 2 van 2
    • The battery will be attached to the back cover with sticky tape. Unplug the wires connecting the battery to the speaker.
    • Using one of the four blue opening tools, pry the battery off of the back cover.
  5. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: stap 6, afbeelding 1 van 1
    • Stick the new battery to the back cover using sticky tape.
  6. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: stap 7, afbeelding 1 van 1
    • Connect the wire from the new battery to the bluetooth speaker.
  7. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: stap 8, afbeelding 1 van 3 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: stap 8, afbeelding 2 van 3 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: stap 8, afbeelding 3 van 3
    • Place cover back on and using the iFixit screwdriver PH000, screw the ten screws back onto the back cover.
Conclusie
Erin Steele
649 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S5-G2, Botvin Spring 2017 Lid van UMass Dartmouth, Team S5-G2, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G2
2 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 295
