Inleiding
This guide gives an in depth explanation of replacing the auxiliary port in the Insignia Bluetooth Speaker. Read if you want step by step instructions on how to replace the auxiliary port. If you have any physical disability in your hand, wrist, or arm please consider having a different individual because these tasks require steady hands.
Wat je nodig hebt
Stap 1 Battery
Voorzichtig: stappen 1-4 komen van een handleiding die in bewerking is.
Remove the rubber sleeve.
Once the battery and back cover have been successfully removed, use the sauter by placing the soldering iron on one side of the auxiliary port button.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Once the metal is heated, use a pair of tweezers to grab the part and pull it off of the circuit board. Be careful not to alter the circuit board in any way with the heat. Also, be careful when removing the part because the metal will be very hot.
