Ga door naar hoofdinhoud
Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement
Wat je nodig hebt
  1. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Front Case: stap 1, afbeelding 1 van 3 Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Front Case: stap 1, afbeelding 2 van 3 Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Front Case: stap 1, afbeelding 3 van 3
    • Flip the device over so the back panel faces up.
    • Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
    • You may want to use a flashlight during this step, as the screws are hard to see.
    • Make sure to firmly connect your screwdriver with the head of the screw. A loose connection can strip the screw head, making the screws nearly impossible to remove.
  2. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement: stap 2, afbeelding 1 van 1
    • Take the screws out and set them aside.
    • Be sure to set them somewhere flat, so they don't roll away.
    • Gently pull the front panel and back panel apart to open the device.
  3. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Tip-Over Safety Switch: stap 3, afbeelding 1 van 3 Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Tip-Over Safety Switch: stap 3, afbeelding 2 van 3 Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement, Tip-Over Safety Switch: stap 3, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the 1.3mm screw on the black rectangle above the Tip-Over Safety Switch.
  4. Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement: stap 4, afbeelding 1 van 3 Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement: stap 4, afbeelding 2 van 3 Insignia NS-HTMC01-B Tip-Over Safety Switch Replacement: stap 4, afbeelding 3 van 3
    • Use a Phillips #2 screwdriver to remove the 0.9mm screw from the back panel of the Tip-Over Safety Switch.
    • Remove the back panel and the Tip-Over Safety Switch.
Conclusie
Rebecca Nunez
201 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 377
