Inleiding
Because the antenna is an external component of the device, it can easily be broken and will need replacing. You must remove the rear panel first before replacing the antenna.
Wat je nodig hebt
Be sure the radio is turned off by pressing the red power button.
Or, if using the charger, remove the power cord.
Using the J1 Philip's head screwdriver, remove the 4 screws from the back side of the radio.
Één andere persoon heeft deze handleiding voltooid.
