Ga door naar hoofdinhoud
Insignia NS-F12R6-SS Motor Housing Replacing
Wat je nodig hebt
  1. Insignia NS-F12R6-SS Motor Housing Replacing, Front Cage: stap 1, afbeelding 1 van 2 Insignia NS-F12R6-SS Motor Housing Replacing, Front Cage: stap 1, afbeelding 2 van 2
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Motor Housing Replacing: stap 2, afbeelding 1 van 1
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Motor Housing Replacing: stap 3, afbeelding 1 van 1
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Motor Housing Replacing, Fan Blade: stap 4, afbeelding 1 van 1
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Motor Housing Replacing: stap 5, afbeelding 1 van 1
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
  6. Insignia NS-F12R6-SS Motor Housing Replacing, Back Cage: stap 6, afbeelding 1 van 1
    • Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
  7. Insignia NS-F12R6-SS Motor Housing Replacing: stap 7, afbeelding 1 van 1
    • Pull the back cage off.
  8. Insignia NS-F12R6-SS Motor Housing Replacing, Oscillation Button: stap 8, afbeelding 1 van 2 Insignia NS-F12R6-SS Motor Housing Replacing, Oscillation Button: stap 8, afbeelding 2 van 2
    • Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
  9. Insignia NS-F12R6-SS Motor Housing Replacing: stap 9, afbeelding 1 van 1
    • Remove the oscillation knob.
  10. Insignia NS-F12R6-SS Motor Housing Replacing, Motor Housing: stap 10, afbeelding 1 van 1
    • Use your fingers to gently pull the power knob directly away from the motor housing.
  11. Insignia NS-F12R6-SS Motor Housing Replacing: stap 11, afbeelding 1 van 1
    • Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
  12. Insignia NS-F12R6-SS Motor Housing Replacing: stap 12, afbeelding 1 van 2 Insignia NS-F12R6-SS Motor Housing Replacing: stap 12, afbeelding 2 van 2
    • Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
  13. Insignia NS-F12R6-SS Motor Housing Replacing: stap 13, afbeelding 1 van 1
    • Pull the front face of the motor housing off toward the front of the rotor.
  14. Insignia NS-F12R6-SS Motor Housing Replacing: stap 14, afbeelding 1 van 2 Insignia NS-F12R6-SS Motor Housing Replacing: stap 14, afbeelding 2 van 2
    • Remove the 10 mm triangular-headed bolt with a Phillips #3 screwdriver.
  15. Insignia NS-F12R6-SS Motor Housing Replacing: stap 15, afbeelding 1 van 1
    • Slide the back end of the motor housing away from the front of the rotor.
  16. Insignia NS-F12R6-SS Motor Housing Replacing: stap 16, afbeelding 1 van 1
    • Remove the small piece of paper hanging on the power button.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Hank
1.142 Reputatie
8 handleidingen geschreven
CSU Fullerton, Team S2-G1, Bruce Fall 2018 Lid van CSU Fullerton, Team S2-G1, Bruce Fall 2018
CSUF-BRUCE-F18S2G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 1,655
