Ga door naar hoofdinhoud
Insignia NS-CLOPP2 Motherboard Replacement
Wat je nodig hebt
  1. Insignia NS-CLOPP2 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • First, remove the front screen. (See prerequisite screen removal guide.)
  2. Insignia NS-CLOPP2 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool to gently pry the motherboard forward and away from the rest of the device.
  3. Insignia NS-CLOPP2 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Gently lift the motherboard up and out, making sure that you don't disassemble any of the wires in place by pulling too hard.
  4. Insignia NS-CLOPP2 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • To fully remove the motherboard from the clock, use wire cutters to carefully sever the connections between the motherboard and the wires attached.
    • To reassemble your device, follow these instructions in reverse order.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Dilini De Silva
757 Reputatie
5 handleidingen geschreven
Marist, Team 1-1, Laflen Spring 2015 Lid van Marist, Team 1-1, Laflen Spring 2015
MARS-LAFLEN-S15S1G1
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 98
