Ga door naar hoofdinhoud
Insignia NS-CLOPP2 Antenna Replacement
Wat je nodig hebt
  1. Insignia NS-CLOPP2 Antenna Replacement, Antenna: stap 1, afbeelding 1 van 1
    • Follow steps on removing the motherboard as a prerequisite.
    • Gently move the motherboard back, revealing the thin black wire that is the antenna. The antenna wire is, on the outside, located on the lower, middle back. Follow the wire from the outside to the inside to make sure it's the correct one.
  2. Insignia NS-CLOPP2 Antenna Replacement: stap 2, afbeelding 1 van 1
    • Pull the wire up, making sure it's connected to the motherboard from the back side. To replace the wire, cut it completely from the motherboard.
  3. Insignia NS-CLOPP2 Antenna Replacement: stap 3, afbeelding 1 van 1
    • To re-attach the antenna cord to the motherboard, use a soldering tool to connect the wire to the same spot it was originally attached to.
  4. Insignia NS-CLOPP2 Antenna Replacement: stap 4, afbeelding 1 van 1
    • Make sure the wire is securely in place in the correct area of the clock, labeled "antenna" from the outside.
Conclusie
Dilini De Silva
757 Reputatie
5 handleidingen geschreven
Marist, Team 1-1, Laflen Spring 2015 Lid van Marist, Team 1-1, Laflen Spring 2015
MARS-LAFLEN-S15S1G1
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 100
