Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Deze stap is niet vertaald. Help het te vertalen
Begin by using a metal spudger to peel back the adhesive sticker and locate the 11mm screw beneath the sticker.
Using a plastic opening tool, peel off the adhesive gel stoppers
Continue peeling the rest of the gel stoppers from the bottom of the device.
Begin unscrewing the six 11mm screws with a Phillips head screw driver.
Once you peel of the bottom from the device, you will see the motherboard.
Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
Locate the four plugs connecting the motherboard to the rest of the device.
Remove the plug to your right from the motherboard.
Remove the plug in the front of the lcd screen plug.
Remove the LCD screen plug last. Then, follow the following instructions in reverse to replace the old motherboard with the new one.
