Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Onderdelen
Geen onderdelen opgegeven.
  1. Locate the bottom of the device.
    • Locate the bottom of the device.
  2. Begin by using a metal spudger to peel back the adhesive sticker and locate the 11mm screw beneath the sticker.
    • Begin by using a metal spudger to peel back the adhesive sticker and locate the 11mm screw beneath the sticker.
  3. Locate the 11mm screw beneath the sticker.
    • Locate the 11mm screw beneath the sticker.
  4. Using a plastic opening tool, peel off the adhesive gel stoppers
    • Using a plastic opening tool, peel off the adhesive gel stoppers
  5. Continue peeling the rest of the gel stoppers from the bottom of the device.
    • Continue peeling the rest of the gel stoppers from the bottom of the device.
  6. Begin unscrewing the six 11mm screws with a Phillips head screw driver.
    • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
  7. Once you peel of the bottom from the device, you will see the motherboard.
    • Once you peel of the bottom from the device, you will see the motherboard.
  8. Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  9. Lift the motherboard from the device.
    • Lift the motherboard from the device.
  10. Locate the four plugs connecting the motherboard to the rest of the device.
    • Locate the four plugs connecting the motherboard to the rest of the device.
  11. Begin with remove the plug to your left.
    • Begin with remove the plug to your left.
  12. Remove the plug to your right from the motherboard.
    • Remove the plug to your right from the motherboard.
  13. Remove the plug in the front of the lcd screen plug.
    • Remove the plug in the front of the lcd screen plug.
  14. Remove the LCD screen plug last. Then, follow the following instructions in reverse to replace the old motherboard with the new one.
    • Remove the LCD screen plug last. Then, follow the following instructions in reverse to replace the old motherboard with the new one.
Conclusie
Erik
405 Reputatie
4 handleidingen geschreven
USF Tampa, Team 9-3, Leahy Winter 2015 Lid van USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Leden
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 77
