Ga door naar hoofdinhoud
Insignia NS-CLIP02 30-Pin Connector Replacement
Wat je nodig hebt
  1. Insignia NS-CLIP02 30-Pin Connector Replacement, 30-Pin Connector: stap 1, afbeelding 1 van 1
    • Locate the bottom of the device.
  2. Insignia NS-CLIP02 30-Pin Connector Replacement: stap 2, afbeelding 1 van 1
    • Begin by using the Metal Spudger to peel back the adhesive sticker and locate the screw beneath the sticker.
  3. Insignia NS-CLIP02 30-Pin Connector Replacement: stap 3, afbeelding 1 van 1
    • Locate the 11mm screw beneath the sticker.
  4. Insignia NS-CLIP02 30-Pin Connector Replacement: stap 4, afbeelding 1 van 1
    • Using the Plastic Spudger, peel off the adhesive gel stoppers.
  5. Insignia NS-CLIP02 30-Pin Connector Replacement: stap 5, afbeelding 1 van 1
    • Continue peeling the rest of the gel stoppers from the bottom of the device.
  6. Insignia NS-CLIP02 30-Pin Connector Replacement: stap 6, afbeelding 1 van 1
    • Begin unscrewing the six 11mm screws with a Phillips head screw driver.
  7. Insignia NS-CLIP02 30-Pin Connector Replacement: stap 7, afbeelding 1 van 1
    • Once you peel off the bottom from the device, you will see the motherboard.
  8. Insignia NS-CLIP02 30-Pin Connector Replacement: stap 8, afbeelding 1 van 1
    • Unscrew the 9.5mm screw located near the center of the motherboard with a Phillips head screw driver.
  9. Insignia NS-CLIP02 30-Pin Connector Replacement: stap 9, afbeelding 1 van 1
    • Lift the motherboard from the device.
  10. Insignia NS-CLIP02 30-Pin Connector Replacement: stap 10, afbeelding 1 van 1
    • Locate the four plugs connecting the motherboard to the rest of the device.
  11. Insignia NS-CLIP02 30-Pin Connector Replacement: stap 11, afbeelding 1 van 1
    • Begin with removing the plug to your left.
  12. Insignia NS-CLIP02 30-Pin Connector Replacement: stap 12, afbeelding 1 van 1
    • Remove the plug to your right from the motherboard.
  13. Insignia NS-CLIP02 30-Pin Connector Replacement: stap 13, afbeelding 1 van 1
    • Remove the plug in front of the LCD screen plug.
  14. Insignia NS-CLIP02 30-Pin Connector Replacement: stap 14, afbeelding 1 van 1
    • Remove the LCD screen plug. Then, follow the previous instructions in reverse, replacing the old motherboard with the new one to fix the 30-Pin Connector.
Conclusie
Erik
405 Reputatie
4 handleidingen geschreven
USF Tampa, Team 9-3, Leahy Winter 2015 Lid van USF Tampa, Team 9-3, Leahy Winter 2015
USFT-LEAHY-W15S9G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 216
