Ga door naar hoofdinhoud
Insignia NS-BCDCAS1 CD Laser Lens Replacement
Wat je nodig hebt
  1. Insignia NS-BCDCAS1 CD Laser Lens Replacement, Outer Panels: stap 1, afbeelding 1 van 2 Insignia NS-BCDCAS1 CD Laser Lens Replacement, Outer Panels: stap 1, afbeelding 2 van 2
    • Turn the boombox around to see the back, and then flip it upside down.
    • Insert a 2.5mm flathead driver into the two holes next to the battery compartment.
    • Turn the driver counterclockwise several times to loosen and pull out the 17mm screw.
  2. Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 2, afbeelding 1 van 1
    • Peel off the two black square foams in front of the battery compartment to reveal a screw under each one.
  3. Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 3, afbeelding 1 van 2 Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 8mm screws using a 2.5mm flathead driver.
    • The front grey panel will loosen up once the final screw is removed.
  4. Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 4, afbeelding 1 van 1
    • Turn the boombox on its back.
    • Release the front panel by pushing down on the latches holding the panels together.
    • There are four silver latches on the top side of the panel and one on the bottom.
    • Do not force the panel comletely off, there are cables attached inside.
  5. Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 5, afbeelding 1 van 2 Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 5, afbeelding 2 van 2
    • Turn the boombox around to view the back and lift the handle up.
    • Using the same driver with 2.5mm flathead, remove the two 14mm screws under the handle.
    • Gently lift the black top but do not pull completely away.
  6. Insignia NS-BCDCAS1 CD Laser Lens Replacement, CD Laser Lens: stap 6, afbeelding 1 van 1
    • Unplug the red and black wires from the large yellow motherboard by pulling upwards.
  7. Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 7, afbeelding 1 van 1
    • Unplug the thick, white and pink cord from underneath the black top by pulling downwards.
  8. Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 8, afbeelding 1 van 1
    • Remove the black shiny strip from both ends of the white motherboard adaptor.
  9. Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 9, afbeelding 1 van 1
    • Using a Phillips #0, remove the two 11mm screws attached to the green legs underneath the top panel.
  10. Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 10, afbeelding 1 van 1
    • With a plastic opening tool, take off the red rings on the other two green legs.
    • The red rings fall off easily once loosened.
  11. Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 11, afbeelding 1 van 1
    • Using a JIS 1, remove the 8mm screw on the grey, square plate.
  12. Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 12, afbeelding 1 van 3 Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 12, afbeelding 2 van 3 Insignia NS-BCDCAS1 CD Laser Lens Replacement: stap 12, afbeelding 3 van 3
    • Slide the silver bar out.
    • Everything will be loosened. Support it with your hand
    • The square cube with the tiny lense is loosened. Slide it down to take out of the nook.
    • Detach the black tape so the cube is completely by itself. Replace the cube with a new one.
Conclusie
Erin King
215 Reputatie
2 handleidingen geschreven
CSU Fullerton, Team 2-5, Bruce Fall 2016 Lid van CSU Fullerton, Team 2-5, Bruce Fall 2016
CSUF-BRUCE-F16S2G5
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 966
