Ga door naar hoofdinhoud
Insignia NS-B2110 Transformer Replacement
Wat je nodig hebt
  1. Insignia NS-B2110 Transformer Replacement, Battery: stap 1, afbeelding 1 van 2 Insignia NS-B2110 Transformer Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Transformer Replacement: stap 2, afbeelding 1 van 2 Insignia NS-B2110 Transformer Replacement: stap 2, afbeelding 2 van 2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
  3. Insignia NS-B2110 Transformer Replacement, Bottom Panel: stap 3, afbeelding 1 van 1
    • With a Phillips #2 screwdriver, remove two 2mm screws.
  4. Insignia NS-B2110 Transformer Replacement: stap 4, afbeelding 1 van 2 Insignia NS-B2110 Transformer Replacement: stap 4, afbeelding 2 van 2
    • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
    • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  5. Insignia NS-B2110 Transformer Replacement: stap 5, afbeelding 1 van 3 Insignia NS-B2110 Transformer Replacement: stap 5, afbeelding 2 van 3 Insignia NS-B2110 Transformer Replacement: stap 5, afbeelding 3 van 3
    • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
    • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
    • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
  6. Insignia NS-B2110 Transformer Replacement, Transformer: stap 6, afbeelding 1 van 2 Insignia NS-B2110 Transformer Replacement, Transformer: stap 6, afbeelding 2 van 2
    • Using a Phillips #2 screwdriver, remove two 4mm screws from the transformer box.
    • Remove the transformer and set it to the side.
  7. Insignia NS-B2110 Transformer Replacement: stap 7, afbeelding 1 van 1
    • Remove the solder connecting the two yellow wires to the green quarter-circle board.
  8. Insignia NS-B2110 Transformer Replacement: stap 8, afbeelding 1 van 3 Insignia NS-B2110 Transformer Replacement: stap 8, afbeelding 2 van 3 Insignia NS-B2110 Transformer Replacement: stap 8, afbeelding 3 van 3
    • There will be a strip of electrical tape securing the converter. Use scissors to carefully remove this tape.
    • Use a Phillips #2 screwdriver to remove two 4mm screws from the converter.
    • Remove the converter. There will be a plastic casing that slides off; set this aside.
  9. Insignia NS-B2110 Transformer Replacement: stap 9, afbeelding 1 van 1
    • Remover the solder from the red and yellow wires on the converter.
Conclusie
Jacob Phillips
313 Reputatie
3 handleidingen geschreven
Cal Poly, Team 4-31, Amido Fall 2013 Lid van Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 10
Altijd: 310
